Driver's quarter window won't open
Old Mar 10, 2015 | 04:09 PM
ahwy111's Avatar
Question Driver's quarter window won't open
1995 XJS - Convertible hood works fine as does passenger quarter window. I follow the manual instructions, but no luck. The driver's side quarter window will not open. The hood is latched, the handbrake is applied, I depress and hold the hood switch. The motor(s) start and only the passenger quarter window lowers. I depress and hold the hood switch again, the motor(s) sound and after the time delay (as specified in the manual), passenger quarter window closes properly. More simply stated, the hood and passenger quarter window operate properly, the driver quarter window is stuck closed.
Suggestions?
Last edited by GGG; Mar 10, 2015 at 06:12 PM. Reason: emphasise Model & Year. Remove personal email address
Old Mar 10, 2015 | 06:11 PM
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Please add vehicle details to your forum Signature - your profile shows you as having a 2003 XJ8......?
Old Mar 10, 2015 | 06:58 PM
Bc xj's Avatar
Try swapping the relay between the left and right window. Thats a simple test and should take minutes. After that check power at relay plug. Compare with working side.
Old Mar 10, 2015 | 08:23 PM
Safari's Avatar
I had the same problem. The solution was to take apart the motor and clean the brushes and commutator. The motor has since worked perfectly.
Mark
Old Mar 10, 2015 | 08:59 PM
Ezrider's Avatar
Old Mar 11, 2015 | 08:56 AM
malc4d's Avatar
Those rear windows seem to be a problem with the XJS. Mine decide (usually when its about to rain...) themselves when to work or not.
Old Mar 12, 2015 | 06:23 AM
texasscot's Avatar
Suggestions?
I have a 1990 so not sure if this applies but... One of mine stopped working and it was a mechanical issue associated with degradation of the internal drive rubber thing producing pieces which jammed the worm gear. Diagnosis for me was 12V hitting the motor on cue - voltmeter into the disconnected connector - and, when removed and bench tested, current draw but no movement. There are other threads on fixes for this specific problem but if you need help let me know. i fixed one and within a month the other did the same thing. fixed it too and not had any trouble since.
Old Nov 26, 2015 | 10:44 AM
black_prophet's Avatar
question...on my 1995 my top and quarter windows go up, windows stuck up now, but won't go down. my convertible top will close fine, but i have to let in down manually. Could this be the roof switch in the center console?
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
philwarner
Sep 3, 2015 10:14 PM
