Ecu removal
Old Apr 18, 2025 | 09:51 AM
wardhill68's Avatar
Default Ecu removal
I’ve searched for a diy on the ecu removal and cleaning but most search results seem to revolve around the earlier v12’s. Mine is a ‘95 aj16. I believe the ecu is in the passenger foot well behind the right side kick panel. If so how is that removed thanks,Jeff
Old Apr 18, 2025 | 11:28 AM
equiprx's Avatar
Should not be that difficult.
I think there are at most only three fasteners on the panel.
Typically of Jaguar, they are probably not all the same.
One is probably a plastic 8mm nut and the other(s) are either Phillips or Posi-Drive.
Just shoot a pic of the label on the ECU.
Old Apr 19, 2025 | 09:39 AM
wardhill68's Avatar
My ecu
My ecu
Old Apr 19, 2025 | 03:47 PM
orangeblossom's Avatar
Removing the ECU from a 1995 4.0LXJS
Old Apr 20, 2025 | 08:39 AM
wardhill68's Avatar
Thank you found it got it out
Old Apr 20, 2025 | 08:50 AM
equiprx's Avatar
I checked my ECU against the pic you sent.
Unfortunately the numbers on the 95 are different than the 94.
I doubt the connectors would be the same either.
mushinnoshin
Aug 7, 2015 01:25 AM
Running Man
Mar 4, 2011 03:31 PM
BaDAss03STR
Sep 10, 2008 09:18 AM
BaDAss03STR
Sep 10, 2008 09:17 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
