Emergency Brake Light on Dash
Old Jan 11, 2020 | 03:15 PM
rickystl's Avatar
Default Emergency Brake Light on Dash
Hello again. Something I forgot to mention in my original Thread below. When applying the emergency brake - which works perfectly - the light will come on in the dash as normal. But once the brake is released, the light still stays on. The brakes releases correctly. Aften driving a short while, the light will eventually disappear. So, I think there is a "sticky" switch somewhere. Maybe by the emergency brake handle ? Thanks for any advise.
Rick
Old Jan 11, 2020 | 03:40 PM
Bez74's Avatar
Hello Rick
Again - 16 years difference between our cars - but on mine - the dash light is operated by a limit switch found on the back of the handbrake assembly. Very easy to get to on mine as I have very basic electrical circuits (no electric seats - or heaters,etc). A lot more difficult on yours
Mine is covered by a hard plastic part - maybe yours is covered by fabric and can be rolled up and limit switch squirted/cleaned that way?
Steve
Old Jan 11, 2020 | 09:23 PM
stran0020's Avatar
In the picture that Steve posted I had to bend the metal tab on the switch quite a bit to make a reliable contact.
Old Jan 12, 2020 | 01:24 AM
VancouverXJ6's Avatar
I just hold the button in and firmly lift the handle up and down abit to 'seat' it for lack of a better term but not cranking it up. Also don't do what I did and neglect to check gauge bulbs periodically lol...I must of driven off a few times with the E brake on before remembering the bulb was out.
Old Jan 12, 2020 | 08:26 AM
rickystl's Avatar
Hi Steve
Thanks for the pic. Yes, mine has a vinyl cover on it that looks like I can just roll up to get access to the switch. I can use an electrical parts cleaner. And, I have a spray lubricant that can be used on electrical parts. That's probably all it needs. I'll do this when the car comes back from the shop. Thanks again.
Rick
Old Feb 4, 2020 | 10:17 AM
rickystl's Avatar
UPDATE My procedure for applying and releasing the parking brake was correct. The dash light would just stay on after release of the brake handle, but would eventually go out after driving a while. So I inspected the limit switch as mentioned above. Sure enough it was just "sticking" a bit. Used some electrical parts cleaner (that leaves a thin oil film) and that seems to have cured the problem. Thanks again for the help. This Forum is great.
Rick
E Gibbs
Dec 27, 2016 01:31 AM
Steve Badger
May 7, 2016 05:43 AM
yabaman
Mar 24, 2015 03:53 PM
Boeingtravel95
Jul 6, 2013 11:50 PM
daboss085
Oct 19, 2012 04:54 AM
