Engine bay pics.
Mish
If you mean the ATS plug is hanging loose with no sensor on it, then the fuelling will be enrichened by the ECU, about 5% (from memory). This is a feature of the system.
Greg
Greg
Well, that's nice to now, will keep it in mind, thanks!
ive got a vacuum line that comes off the brake booster and runs to the right hand side. its metal. mine has a rubber hose on the end with a screw in it. any ideas where it goes?
ive also got a large diameter vacuum fitting coming off the underside of the right hand manifold thats capped off.
This canister is supposed to keep extra vacuum, in case if you need to hit your brakes fast, I guess.
See mine here, it is red on this pic.
If he still has one in there, some wise idiots think that they can remove anything the do not understand. My predecessor was one of them.
Greg
my jag has no cruise, no smog, and no AC.
Hmmm...dunno why it wouldn't post the 1st time, but I'll try again. My engine bay, it isn't finished yet though. I still have the injection harness sitting on top without the heat shielding on it. Makes it easier to move out of the way for now, but once I've worked the bugs out of the engine I'll wrap it up and tuck it out of the way.
