Exhaust olives
Old Dec 28, 2018 | 02:40 PM
brinny's Avatar
Default Exhaust olives
As I continue putting things back together on my v12, the exhaust is up next. Is it necessary to put paste on the olives that connect the pipes or should they seal without? Thanks in advance for the help that is so freely given and gratefully received on here. Happy new year!
Old Dec 28, 2018 | 08:18 PM
JigJag's Avatar
I used the paste. They sealed with the paste on em. You try no paste and we’ll know if that works too.
Old Dec 28, 2018 | 11:01 PM
brinny's Avatar
Hmmm
Old Dec 28, 2018 | 11:29 PM
Vee's Avatar
Vee
I did not use paste on my AJ16 exhaust. No issues.
Using aftermarket olives seemed to make a bigger difference. I had some that didn’t fit! The OEM looked and felt of better quality.
Old Dec 29, 2018 | 01:36 AM
brinny's Avatar
I will probably use a bit of paste but on first fit up things didn’t look too bad. I cleaned the boxes up with a wire brush in the grinder/drill and was amazed how well they came up. Someone told they are of a low grade stainless . Makes sense. Not too important at this stage that they are 100 % gas tight I suppose as long as something like. That paste makes a mess and looks bad I think.
Old Dec 29, 2018 | 03:07 AM
Greg in France's Avatar
The crushable olives between the manifold and the downpipes benefit from a smear. The other solid ones cannot do any harm, but are not actually needed. A smear on the slipjoint into the back boxes in the exhaust tunnel is worth doing.
Greg
Old Dec 29, 2018 | 07:29 AM
brinny's Avatar
Well that’s one side done this morning, bit easier than I thought.
Old Dec 29, 2018 | 12:51 PM
orangeblossom's Avatar
Not a big fan of exhaust paste myself, especially if you ever have to take it apart!
Ask me how I know! (or rather don't)
Old Dec 30, 2018 | 01:29 PM
J_C_R's Avatar
I didn't use paste on mine, no issues after 2 months.
Thanks,
John
1987 XJ-S V12
Old Jan 3, 2019 | 07:23 PM
ronbros's Avatar
do those olives come in a glass JAR?
ron
xjrwithproblems
Aug 10, 2019 07:30 AM
J_C_R
Oct 3, 2018 11:20 AM
abonano
Jan 7, 2015 02:20 PM
DJ99
May 24, 2012 08:10 PM
gragner66
Sights N Sounds
Oct 14, 2011 07:04 PM
