facelift 4.0 backdate?
Old Feb 12, 2019 | 11:19 PM
Brewtech's Avatar
Default facelift 4.0 backdate?
Hi guys. Im jumping back into an XJS, Im picking up a facelift car and I want to go with quad headlights. Will a set from any early model fit? Plug and play? Or do I have to do some rewiring? What parts do I have to make sure I get?
Old Feb 13, 2019 | 05:36 AM
Vee's Avatar
Vee
SNG Barratt sells a kit. I bought it almost 10 years ago and have been very happy with it. That’s going to be your best bet.
Old Feb 14, 2019 | 09:19 AM
Brewtech's Avatar
Thanks but before I go that route, I found an older parts car that still has its headlight units intact... would those work?
Old Feb 14, 2019 | 10:42 AM
Vee's Avatar
Vee
I'm going to say that it should be a direct fit, but it would certainly help to know how far back it came from. If you posted a pic, that would be great too.
You will probably need to construct harness for the two lights. I believe the plug you have for your current headlight only lights up one bulb, now you'll have two and I don't believe you'll be able to use the old wiring.
You can tap into the wires. Black is ground. Blue/white is high beam, Blue/Red is low beam and I can't remember what the daytime driving, or city light wire is attached to. But that's going to be the challenge in making this work.
Old Feb 14, 2019 | 11:19 AM
Brewtech's Avatar
Im going to go look at it soon. If the wiring is not up to my liking... the SNG Barratt kit will do.
Old Feb 15, 2019 | 04:29 AM
VancouverXJ6's Avatar
What are you doing with the old headlights? I'm assuming they are the big single peice? one of mine has a bullet hole in it so I need replacements.
Old Feb 15, 2019 | 03:49 PM
Brewtech's Avatar
mine are patina’d and have been buffed out already so I assume that the light yellowing is internal. Otherwise fully functional and water tight. Im sure you could make better use of them since I doubt my car will ever be at a collectors knitpick fest. Plus Ill be able to recoup any money spent on replacement lights. Lemme know
chXFS
May 30, 2022 11:02 PM
CruizinKev
Oct 9, 2017 09:12 AM
lordsinclair
E type ( XK-E )
Jul 25, 2015 07:00 AM
hoodun
Oct 30, 2012 08:23 PM
priest2705
Mar 4, 2011 09:47 AM
