Fan shroud question.
Old Oct 21, 2018 | 09:10 AM
brinny's Avatar
Default Fan shroud question.
Can anyone tell me what the two vinyl flaps are for on the fan shroud? What do they do and are they necessary? Many thanks as usual in advance for any replies.
Old Oct 21, 2018 | 09:15 AM
Daim's Avatar
They are there for a reason. When stationary, they are closed and allow the fans to draw air through the radiator rather than from in the engine bay. When moving, they open allowing for more airflow through the radiator.
Old Oct 21, 2018 | 09:31 AM
Ezrider's Avatar
i second diam's answer
Old Oct 21, 2018 | 09:46 AM
brinny's Avatar
Much obliged. They are missing on mine and so I will replace them.
Old Oct 22, 2018 | 01:06 AM
Dukejag's Avatar
What do they look like, can't see any on mine.
Picture would be most appreciated.. new 12 owner
Old Oct 22, 2018 | 02:38 AM
orangeblossom's Avatar
Hi Duke
The Flaps are beside the Fan, set into the Fan Shroud not on the Actual Fan itself
Old Oct 22, 2018 | 05:18 AM
Daim's Avatar
Flaps are top right... Would sit bottom left.
The shroud is upside down here but the flaps are the top right rectangles...
Old Oct 22, 2018 | 07:24 AM
Doug's Avatar
On mine the flaps had become petrified.
I bought some utility-grade sheet rubber (1/16th inch thick) on Ebay to replace 'em. It's just a matter of drilling out the rivets on the retainer straps.
Doug
May 17, 2016 08:11 PM
orangeblossom
May 29, 2015 11:31 AM
orangeblossom
May 15, 2015 04:07 PM
orangeblossom
May 15, 2015 08:30 AM
spielnicht
Aug 13, 2013 12:06 PM
