A few Questions About a Used Marelli Ignition Engine I Bought
Old Jun 9, 2018 | 09:24 AM
mikebaker3's Avatar
Thumbs down A few Questions About a Used Marelli Ignition Engine I Bought
My 90 XJS Convertible with 107,000 miles developed a rod knock.
I will eventually tear down the engine and rebuild, but short term, I decided to buy a used engine instead. The engine in the car is SN 8S73301SA.
I bought the new to me used engine from SW Engines in Eugene Oregon. It arrived yesterday. I noticed a few things that look different than my engine, although it is a Marelli ignition engine.
Serial Number for this engine is 8S82332SA. DY247 is stamped to the left of the serial number. There is an additional web above left of the transmission mounting flange. The exterior of the block for 8S73301SA is smooth surface rough cast. Engine 8S82332SA has hashmarks cast on the exterior of the block. The JAGUAR embossed on the left side of this engine is different whereas the JAGUAR embossed on 8S73301SA is in a hexagon.
Other than these differences, the engine seems to be equipped the same.
What can you tell me about this engine?
Attached Thumbnails A few Questions About a Used Marelli Ignition Engine I Bought-new-engine-block-pn-2.jpg   A few Questions About a Used Marelli Ignition Engine I Bought-jaguar-casting-left-side.jpg   A few Questions About a Used Marelli Ignition Engine I Bought-air-valve-new-engine.jpg   A few Questions About a Used Marelli Ignition Engine I Bought-new-engine-sn-number-2.jpg   A few Questions About a Used Marelli Ignition Engine I Bought-number-left-sn.jpg
A few Questions About a Used Marelli Ignition Engine I Bought-engine-sn-close-up.jpg
Old Jun 9, 2018 | 09:27 AM
mikebaker3's Avatar
I forgot to mention that this engine, like the original has the new style rear crank seal.
Old Jun 9, 2018 | 10:12 AM
Daim's Avatar
All Marellis seem to have the lip seal at rear. Mine (mid 89) has it too... Not available new anymore. But you can get the correct part from Bentley...
Old Jun 9, 2018 | 10:18 AM
Greg in France's Avatar
ENGINE Code
Breakdown for 8S82332SA
PREFIX : 8S Jaguar XJ-S 12 5.3L 12 cylinder SERIAL : 82332 Marelli digital ignition HE (High Efficiency). NGK BR7EFS Spark Plugs. Gap .025". Bosch 115A alternator. SUFFIX : SA Standard Compression with Grade A pistons & liners. (11.5:1 Compression)MFG YEAR (GUESS): JUL 1981 to LATER
This is the place to decode all XJS numbers:http://jaguar.professional.org/jagvin.php
Old Jun 9, 2018 | 10:23 AM
mikebaker3's Avatar
Daim;
You can buy new rear seals from XKs unlimited if you need one.
Old Jun 9, 2018 | 01:16 PM
Daim's Avatar
Originally Posted by mikebaker3
Daim;
I bought a new one from SNG - which came in a Bentley bag... That is why I know. Jaguar themselves claim NLA.
Old Jun 9, 2018 | 04:43 PM
baxtor's Avatar
The early marelli motors (up to #66782) had rope seal Daim. Mid '89 was about right.
Old Jun 9, 2018 | 09:30 PM
mikebaker3's Avatar
Does anyone know about when the change to the crosschecked Blocks started?
Anglicomarine0326
May 17, 2018 09:46 PM
XJsc-guy
Sep 29, 2013 09:20 AM
tdickins
Feb 22, 2013 06:43 PM
eathernet
Sep 3, 2012 04:35 PM
Flint Ironstag
Dec 12, 2011 05:26 PM
