fuel line pipe/hose to FPR
Old Apr 28, 2021 | 01:16 PM
BradsCat's Avatar
Default fuel line pipe/hose to FPR
Looking for a vender source for a new fuel line pipe/hose from the fire wall barbed connection point to the intake FPR on the passenger side of the motor. My usual sources: Welsh, XKs Unlimited, SNG Barrett are all showing not available.
If none found what are other viable alternatives, e.g. straight hose to the fuel rail?
Old Apr 28, 2021 | 01:41 PM
orangeblossom's Avatar
Hi Brad
I would think your local Hydraulic Shop could easily make you one up
Old Apr 28, 2021 | 01:57 PM
Thorsen's Avatar
Do you have the "old" hose assembly? It's not that difficult to remove the old hose from the fitting and replace it with standard 5/16" EFI hose.
In the picture below, the bottom hose still has the hose and collar attached. If you carefully remove the collar (I like to slice it with a Dremel, then pry it off) you can slide the old hose off. That's what's at the top of the picture. You can just slide a new 5/16" hose on.
Last edited by Thorsen; Apr 28, 2021 at 03:49 PM. Reason: Added picture for clarity
Old Apr 30, 2021 | 06:24 PM
BradsCat's Avatar
Old Apr 30, 2021 | 09:07 PM
Or this path Brad.
After I did this, I moved the fuel filter from the boot to the RHF corner of the engine bay, and altered this hose to suit that.
One less fuel odour source in the boot.
File Type: doc
jag-reflex
Mar 21, 2021 08:45 AM
Qvhk
May 19, 2017 12:16 PM
Dymaxxion
Jul 25, 2015 02:16 PM
cpm53
Dec 23, 2012 05:57 PM
x300killer
Apr 21, 2012 04:22 AM
