Fuel Tank Nipple Seals
Old Jan 23, 2014 | 05:13 AM
bhamilton's Avatar
Default Fuel Tank Nipple Seals
Hello,
I have removed my fuel and surge tanks for KBS Sealing. I am curious if anyone knows where I can get the seals that seal the nipple to the tank on the surge tank return and fuel rail return lines. I attached pictures of what I am referring to. I have since extracted the seals from the tank, but you can see the green colored seal that was left in the tank when the nipple came out. I didn't see these mentioned in "the book".
Thanks,
Bill.
Attached Thumbnails Fuel Tank Nipple Seals-tank-seal.jpg   Fuel Tank Nipple Seals-tank-fitting.jpg
Old Jan 23, 2014 | 07:05 AM
Greg in France's Avatar
I may be wrong about USA spec cars, but on mine the sealing mechanism is a brass "olive" that is a compression fitting. Maybe yours have been removed and changed for the type you illustrate?
If they have, new brass olives can be bought at any old-style hardware store, just measure the O/D of the pipe; it will probably be an imperial size (eg 1/2 inch, 7/16ths etc).
Greg
Old Jan 23, 2014 | 03:07 PM
bhamilton's Avatar
Thanks Greg in France.
It's an olive all right, but I kept nosing around and found this part which is a Viton Olive which is what mine was using. I have 2 on the way. I probably could have used a brass one instead but didn't want to take a chance of dealing with a weird leak after getting the tank back in so figured I better go with the way it was. Anyway.........
Thank you.
Old May 17, 2014 | 04:58 PM
nolapunk's Avatar
where did you find these? i just put my tank back in and want to replace the aged parts from future cracks.
thanks,
1989 XJS 5.3 rouge collection
Old May 18, 2014 | 04:55 AM
bhamilton's Avatar
cbc4720 - Viton Olive
That should do it.
Good luck.
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
ccfulton
Sep 20, 2015 05:15 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
