fuel tank vent routing
Old 08-04-2015, 03:34 PM
catterwaller's Avatar
Default fuel tank vent routing
92 XJS convertable. Does anyone know the routing for the plastic fuel tank vent in the trunk (boot)? When I removed the tank, I forgot which side and where it was routed to. I thought it went rearward to the tail lamp area.
Old 08-06-2015, 09:44 AM
Picture is upside down. but the plastic vent line is the one with the arrow. It is now just running down the right side of the trunk. I don't know which side it should go or where it should connect.
Anyone have diagrams?
Old 08-06-2015, 10:11 PM
Typhoon's Avatar
An easy trick for working on fuel tanks and determining which line does what is to blow into the fittings. Vent fitting will allow air straight in and fuel return will bubble if there is any significant amount of fuel in the tank. The pressure line is obvious as it's the one that has fuel pressurised in it and is usually the largest.
Razor
08-28-2019 08:34 PM
dsnyder586
04-04-2019 02:38 PM
Kodiak
F-Pace (X761) / C-X17
28
07-24-2016 02:31 PM
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
Quick Reply: fuel tank vent routing
