getting ready for an engine rebuild
Old May 19, 2014 | 12:17 PM
xwestonx's Avatar
Default getting ready for an engine rebuild
Since I am looking to modify the engine on my newly acquired 76 XJS eventually and the fact that it has been sitting for a while, I figured stripping the engine down and giving it some fresh components may not be a horrible idea.
Things I plan on doing:
Raise compression (likely euro spec 9:1, but I wouldn't mind 10:1 if possible)
Port and polish heads
Valve job
I plan on converting over to a megasquirt based fuel and ignition management and most likely run a EDIS ignition system.
I am hoping some of the more experienced members can chime in on potential pitfalls of this plan or other factors that I should be looking at as well. I'll be starting a proper build thread soon, but the overall plan is to strip out the car as much as possible, go with a fairly minimalist dash and interior, and have a fun weekend warrior type of car (on a modest budget).
Thanks in advance!
Old May 19, 2014 | 04:16 PM
calvindoesntknow's Avatar
What are your goals? I recently did a performance build flathead motor so I'm pretty familiar
Old May 19, 2014 | 04:54 PM
M90power's Avatar
Valve job
PROFIT!
lol couldnt resist. leave compression stock and boost it! ))))
Old May 19, 2014 | 06:53 PM
xwestonx's Avatar
Haha profit indeed. I haven't decided on a specific HP target, but in the region of 400 (of course more would be nice, but I'm trying to be realistic) sounds like a good ballpark. I've considered boosting it (and am certainly not against it), but I have always loved the sound of a nasty naturally aspirated motor more.
Overall I plan to to do a 5 speed manual swap, I still need to get it up on the lift and verify gear ratio (potentially has a 3.31 rear end, but again I haven't verified this yet), and strip the car down for a group 44/ TRW inspired road car (with the occasional track use).
Old May 19, 2014 | 07:24 PM
Port and polish the heads are a good start. If I were you I'd look into custom pistons. They can be made to work with the jaguar rods with the pin bushings bored out. These can make a whole world of difference, a guy I was talking to locally said they used to be good for 70 hp.
Then look into cams and exhaust.
I'm making my own intakes and exhaust headers.
dsnyder586
Dec 29, 2024 07:39 PM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
sogood
Sep 15, 2015 07:35 AM
TC Johnson
Sep 2, 2015 09:30 AM
