Greetings, and what have I gotten myself into!
Old Nov 13, 2021 | 07:15 AM
AngryRadish's Avatar
Default Greetings, and what have I gotten myself into!
First post here, though I have been lurking about for awhile now.
My wife has always had the 80's XJS as a childhood dream car and we decided it was time to get back into working on cars.
My previous experience has always been with older 60's Buicks, etc. and I have to say Jaguars are quite the challenge!
I originally acquired an '85, somewhat worn, but in overall good shape and the color blue my wife likes (Code JEF). What I DIDN'T know at the time, was that the knock I heard was what is most probably a valve seat, as the previous owner had overheated the engine.
Enter the '88.
Low miles, runs smooth, but otherwise a rough car.
The plan is to remove the '88 engine and transplant it into the '85, along with stealing various bits and bobs from the '88 to replace worn items on the '85.
Current state:
88 is in the garage and we're ALMOST ready to remove the transmission from below as our garage ceiling is too low for a full list as one unit. Not the preferred route, but I want to have the engine out and the destination 85 in the heated garage before the winter weather hits.
The issue is, somehow, someone managed to get the 9/16 bolt into the upper starter bolt position instead of the T12 that is supposed to be there. Grinding down sockets to make them thinner walled has proven ineffective, and I believe my next option is to grind the head off.
I am not overly concerned about damaging the transmission housing since this has shifting issues as well as a bad parking pawl and I do not intend to use it.
After seeing all of the other posts here and thinking about how much help you all have been to me while lurking in the background I thought I would share my own adventure!
Cheers,
Dan
1985
Previous owners' mess
1988
1988 start
1988 tilted down
Wrong bolt
Old Nov 13, 2021 | 05:21 PM
Victory!
I also now realize this "low lift" transmission jack is, in fact, NOT low enough, and I'm going to have to roll the transmission off the jack onto something lower
Old Nov 13, 2021 | 05:29 PM
Xjeffs's Avatar
Nice project you have there. Congrats on your project purchase and you found a good place for help and ideas.
Jeff
Old Nov 13, 2021 | 06:27 PM
jal1234's Avatar
Welcome!
Yeah, that bolt is a bear even when it's the correct one.
What version of Quickjack are you using? 5000lb? Extended version?
Jon
Old Nov 14, 2021 | 05:56 AM
Thanks!
I have the 5000 extended, and I cant say enough good things about it. Not having to constantly jack and place jackstands is quite the change.
After talking with the helpful folks at bendpak, the Jack points are exactly .5" too far for the standard version to fit comfortably.
Originally Posted by jal1234
Welcome!
Jon
Old Nov 14, 2021 | 09:08 AM
orangeblossom's Avatar
Hi Angry Radish
Well done for getting that Bolt out but what make is that Trolley Jack, I've never seen one as wide as that before
Alex
Old Nov 14, 2021 | 09:14 AM
jal1234's Avatar
The jack looks like this one:
https://hftools.com/app60234
Jon
Old Nov 14, 2021 | 04:02 PM
Hi Jon
Cheers for that!
It looks like the same one
Old Nov 14, 2021 | 04:43 PM
I actually looked at that one at HF, ended up getting this one from northern tool
https://www.northerntool.com/shop/to...0984_200640984
Old Nov 15, 2021 | 07:25 AM
Rescue119's Avatar
I wonder the same thing. Lol
You need min 21" of clearance to remove the th400. I had to jack my car up 24" at the lowest point to get it out.
You can rebuild the th400 for cheap. Or sell it as a lot of v8 big block owners want them as these ones have the HD parts inside.
Old Nov 16, 2021 | 09:11 PM
Xjeffs's Avatar
When I dropped my trans, I had it in a floor Jack and a 2×8. When the floor Jack bottomed out I set the 2x8 on a stack of 2 bricks on each side. Then formed a ramp and did it to the floor and dragged it out.
BTW, I sent you a PM.
Old Nov 17, 2021 | 04:54 PM
That is a great idea about forming a ramp, I've been thinking all week about how I wanted to get it down from the jack this weekend before the engine removal.
Also, replied!
Old Nov 25, 2021 | 07:19 AM
Rolled the transmission off onto some foam pads I had around, worked perfectly.
The engine pull went perfectly, however I don't really trust the engine stand with the full weight. The amount of flex is somewhat concerning with such a long block, especially loaded.
My current plan is to grab another engine stand and some more steel, and weld up a stand like over at
Old Jan 1, 2023 | 09:41 AM
An Update,
Now that Summer projects (Deck build) are complete, I can get back to this thing.
Merged 2 hand-crank stands and am quite pleased at the balance and ease I can rotate the motor!
Softball60
Oct 29, 2021 09:35 AM
Some Day, Some Day
Jul 28, 2020 01:22 PM
Some Day, Some Day
Mar 6, 2018 02:11 AM
RaceDiagnostics
May 19, 2013 09:00 AM
Big Cat
Jun 14, 2010 09:10 PM
