Hard Steering Latest development puzzled!!!
Old Feb 21, 2012 | 12:28 PM
Qgregg's Avatar
Default Hard Steering Latest development puzzled!!!
1988 xjs v12 hard to steer, up on jacks front wheels turn easily from stop to stop. Flushed power steering fluid, with the cap off i noticed forcefull circulation of the fluid coming back into the power steering pump. figured that its not a pump issue. No leaks to be found. Put the wheels back on the ground (lowered jacks) cant hardly turn wheel at all. above 10 mph turning is ok. slower gets harder. puzzeled????????????
Old Feb 22, 2012 | 12:02 AM
JameyXJ6's Avatar
Steering gets easier as the car increases speed, that's normal.
My guess is either a weak pump or the rack has a stuck valve or is shot. I'm sure others will chime in though!
Old Feb 22, 2012 | 01:58 AM
warrjon's Avatar
You need to check the pressure on the high pressure line,it should be 1100 to 1200psi. If this is low even 800psi there will be almost no assistance.
Old Feb 22, 2012 | 06:11 AM
MustangSix's Avatar
Failed internal seals on the rack = no assist. It will turn easily off the ground but will be very hard at rest.
The rack is rebuild-able, but is not normally a DIY job.
Old Feb 22, 2012 | 10:13 AM
M90power's Avatar
vapor locked possibly.
Old Feb 23, 2012 | 10:17 AM
Qgregg's Avatar
Damn, i did not want to hear this one.
Old Mar 6, 2012 | 07:10 AM
Qgregg's Avatar
Default latest on hard to steer
O.K Here it is, figured id take the p/s pump off first (easiest) opened it up and to my surprise the clip ring that holds the end cap in place had come 1/2 way out of its crevice. also was evidence of pieces of rubber seal. Ordered another p/s pump with pulley. hope to have it on by the weekend. More will be revealed!!!
Old Mar 6, 2012 | 11:13 PM
JameyXJ6's Avatar
cool...might want to flush the system though
RobertTheBloke
Sep 24, 2015 11:48 AM
WhiteTardis
Sep 17, 2015 09:29 AM
Tipptone
Sep 16, 2015 07:39 AM
Johnken
Sep 15, 2015 05:46 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
