Hazard switch blows fuse
Old Dec 16, 2024 | 04:13 PM
Jag06530's Avatar
Default Hazard switch blows fuse
Hi, currently have no indicators or hazard lights
Fitted new relay and have checked bulbs, cleaned earths, indicator stalk and hazard button electric connectors and contacts on switch cleaned
When we press the hazard switch it blow the 10amp straight away, with the button pressed a red light is illuminated behind the fuse
New fuse and relay add we have no indicators before we even push the button for the hazards
Indicator stalk - lights and high beam work, the button the end I don't know what that does
Any help welcome
Old Dec 17, 2024 | 10:48 AM
Vee's Avatar
Vee
I see this is a 1995 model year.
Where I would start is at the switch. Pull it out and disconnect the wires. See if you trip a fuse when you connect the two wires yourself. That would at least eliminate the switch itself from the problem.
After that, you'll have to check the wires to see if one of them is grounding when it shouldn't. You can do that with a multimeter and see which of the two wires show a ground using the ohm setting.
www.jagrepair.com will have the wire diagrams you will need to go deeper, but we are here to help.
Old Dec 17, 2024 | 11:08 AM
Jag06530's Avatar
Thanks for the help, with the hazard switch discounted the indicators with new relay and fuse add doesn't work
Does the hazard switch need to be installed for the indicators to work ?
Old Dec 17, 2024 | 12:34 PM
Vee's Avatar
Vee
So, according to the wiring diagram, at the fuse, the BROWN wire is coming from the battery. This wire is spliced into Fuse Locations 4 (Radio Memory) and 11 (Trunk Lighting) as well.
1. First thing you could do is pull the 10A fuses at 4 and 11 and see if that helps. If the flashers work with fuses 4 & 11 pulled, then come back and let us know. If they don't, keep going.
2. The BROWN/ORANGE wire going into your switch carries the battery power. First, do an ohm test on the BLACK wire to ground to make sure the switch is grounded. If you cross the BROWN/ORANGE wire with the LIGHT GREEN/PINK wire should fire off the flasher. If that pops the fuse, then the switch is safe.
3. Assuming that works, the next thing to suspect is the Flasher. That is somewhere under the dash panel. I don't know what it looks like, but it should have 4 wires going to it. (1) Light Green/Blue, (2) Light Green/Pink (3) Red(?) and (4) Black. I would run an ohm test on the BLACK wire to ground. Make sure that the flasher is grounded. The RED wire should not be connected to anything, so it might not even exist.
Old Dec 18, 2024 | 04:44 AM
Jag06530's Avatar
Hi, thanks for the latest info
Results
Removing fuses 4 and 11 the hazard switch still blows the fuse and no indicators
Grounds are connected on both relay and hazard switch, beeped tested
With ignition on we connected brown orange and green pink using a wire nothing happened fuse didn't blow nor did the flasher pop off
Therefore is the switch at fault ?
I did put a 25 amp fuse briefly in to see if the relay clicked it did, but no flashing of hazard button or indicators working at any time
Old Dec 18, 2024 | 06:37 AM
Vee's Avatar
Vee
I can’t say for sure whether the switch is at fault until we can get the lights to come on without it.
I don’t have the electrical diagram in front of me, but I thought by crossing the brown/orange and the light green/pink, that should have sent power through the flasher and to the lights. I need to take a second look at that.
I want you to be able to activate the light, bypassing the problem. The other way we can do this is by going in reverse direction. I’ll make recommendations later today.
Old Dec 18, 2024 | 06:50 AM
Jag06530's Avatar
Thanks, if I press the button in very slowly I get about 2 clicks on the relay before the fuse blows
There are no dashboard indicator lights or indicators at any poiint
`Question - does the indicators need a working hazard switch to work ?
Old Dec 18, 2024 | 07:16 AM
Vee's Avatar
Vee
I'm assuming that the turn signals work when you use the stalk on the steering column. If they work, then the only suspect parts can be limited to: (1) Switch (2) Flasher (3) Lighting and Turn Signal Switch. If they don't, then I have underestimated the problem.
The Flasher should operate the lights if it sees power on the LIGHT GREEN/PINK wire. What happens if you disconnect that LIGHT GREEN/PINK wire and apply 12v power to LIGHT GREEN/BLUE wire at the Flasher? That should bypass the flasher, and we should light up the turn signals. (You can cross it with the BROWN/ORANGE or GREEN (with ignition on) wire to do this, if possible)
Old Dec 18, 2024 | 08:32 AM
Jag06530's Avatar
Hi, the car arrived with no relay flasher, we thought that by replacing the relay the hazards and indicators would work
To date they have never worked, indicators or hazards
Old Dec 18, 2024 | 09:16 AM
Vee's Avatar
Vee
Oh, so the indicators don't work, regardless whether you use the stalk to indicate a turn? OK. Have you checked all the light bulbs. It could be as simple as that. I would start there. After that, I believe if the fuse burns out when the switch is depressed, there's likely a problem with the switch. There is a handoff between battery power and switched power at the LIGHT GREEN/PINK wire.
Does the switch blow a fuse when you press it with the ignition off, no key in the steering column? The switch should work with the key in or out, so I'd like to know if anything happens with the key out and the switch pressed.
When you pressed the switch button slowly, and got the clicks on the relay, did the switch ever illuminate, or you don't know.
Old Dec 18, 2024 | 09:28 AM
Jag06530's Avatar
Correct the indicators have never worked
All 4 bulbs have been checked and tested
I will double check ignition 'on and off' no key but I'm pretty sure it blows the fuse wether the key is in or out
There's no illumination I'll double check that
Old Dec 18, 2024 | 10:14 AM
Vee's Avatar
Vee
When crossing the following wires, what happens:
1. Brown/Orange (key off, disconnected from Hazard Switch) & Green/Red (disconnected from Hazard Switch) - I'm hoping your left rear and front turn signal lights turn on.
2. Brown/Orange (key off, disconnected from Hazard Switch) & Green/White (disconnected from Hazard Switch) - I'm hoping your right rear and front turn signal lights turn on.
3. Disconnect the Green wire at the Hazard Switch and press hazard light switch with key out -
4. Disconnect the Brown/Orange wire at the Hazard Switch (green should be connected) and press hazard switch with ignition on -
Old Dec 18, 2024 | 10:28 AM
Jag06530's Avatar
Thanks will get back to you on this
Old Jan 1, 2025 | 09:58 AM
Jag06530's Avatar
Hi, and HNY
Getting back to the hazard switch, one question asked is it illuminating when being pressed, no it does just blows the fuse
I haven't crossed the following wires
Jag06530's Avatar
Does anybody have a hazard switch replacement that's been tested for sale ?
Old Jan 1, 2025 | 02:27 PM
ptjs1's Avatar
Jag06530,
There's a facelift hazard switch on eBay France today.
Paul
Old Jan 1, 2025 | 05:36 PM
Jag06530's Avatar
Originally Posted by ptjs1
Jag06530,
Paul
Hi, do you have link I was scouring the internet and EBay’s across the globe today ?
Old Jan 1, 2025 | 05:39 PM
ptjs1's Avatar
Yes,
I just went to eBay.fr and typed "Jaguar XJS facelift hazard switch". Here's the item:
https://www.ebay.fr/itm/156509976589...Bk9SR6CA3sOEZQ
Old Jan 1, 2025 | 05:47 PM
Jag06530's Avatar
Thanks, wasn’t sure that this would work? Part no. DAC10201 is what we need
Old Jan 1, 2025 | 06:29 PM
ptjs1's Avatar
According to the Jaguar parts website, there were 3 versions, DAC 10104, DAC10201 and DAC 11170, which changed between 1991 & 1996. I don't know whey they changed or what is the difference between them
In theory, your car has DAC 11170 as a 95 car. I also have a late convertible which should have the same switch. I'll look at my car at the weekend.
If your switch looks exactly the same as the one in the advert, including the wiring plug, I suspect it would fit fine.
Paul
