HE V12 Timing
Old Jun 1, 2015 | 06:03 AM
xj-c4.2's Avatar
Default HE V12 Timing
I've seen a never ending list of different timing spec's. Can someone please give me the correct spec please. My workshop manual is totally confusing giving a few different degree's of advance. I have just had the dizzy rebuilt.
Is there a idle spec as well as 3000rpm.
Regards Russell.
The car is
1985 V12HE lucas ignition
Australian delivered.
Old Jun 1, 2015 | 06:33 AM
Here ya go.
HE Tune up.doc
Trimming the timing on a running V12.doc
Old Jun 1, 2015 | 03:55 PM
Jagboi64's Avatar
[QUOTE=xj-c4.2;1239511
[/QUOTE]
18 degrees at 3000 RPM is the official spec, but a very close approximation is 0 at 750 RPM. That's much easier to set.
Old Jun 1, 2015 | 11:46 PM
xj-c4.2's Avatar
Thank you. Mine is about 10 degree's at idle and 24 at 3000 but not pinging at all....but I haven't really pressed it past 4500 rpm.
Old Jun 2, 2015 | 12:47 AM
xj-c4.2's Avatar
Originally Posted by Grant Francis
All righty then...having read your attachments, I'm thinking mine is pretty right. about 10 degrees BTDC at idle the 24 degrees at 3000rpm seems right. A Jaguar workshop manual I have gives a range of 22 to 26 degrees at 3000 rpm.
We checked mine on a hoist, I too do not like the idea of being under the front at 3000 rpm on the ground.
Regards Russell
Old Jun 2, 2015 | 04:46 AM
I would leave it alone, really.
Carefully remove the distributor cap, and drop some Synthetic oil down the shaft, and repeat annually, and forget the beast.
Mine no longer have timing plates, as I have no intention of messing with the timing in any other way than "drive timing", and the chances of having to remove the distributor for any reason are less than zero.
The vac capsule is the only other thing to watch, as it will toast overtime.
Old Jun 2, 2015 | 05:39 AM
xj-c4.2's Avatar
Yep got ya. Had the dizzy re-built and new vac unit. Took two day on and off dropping the dizzy back in and being happy with the timing. Such a little space to work with when adjusting a gear this way and that...
Old Feb 25, 2019 | 01:04 PM
TGman's Avatar
Default Thanks
Been so .long since I fussed with V12s I was lost.
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
Doug
Feb 27, 2019 01:31 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
d a
Sep 3, 2015 02:34 AM
