Help - Clutch problems
Old Jun 2, 2019 | 08:02 AM
leep123's Avatar
Default Help - Clutch problems
Hi all,
My ’90 3.6 manual has developed a clutch issue.
Drove the car last weekend and clutch felt a little odd as free play on the pedal seemed to have increased. Today clutch drag set in after a few hundred yards of driving and I virtually had to push my foot through the floor to disengage.
I have about 1 inch of free play at the pedal which reduces to half of this after vigorous pumping. Fluid is topped up but looks dirty.
At 137k miles and, I believe, still on the original clutch I am fearing the worst but is there any chance this could be a hydraulic issue - maybe slave or master cylinder?
Thanks for reading.
Cheers,
LeeP
Old Jun 2, 2019 | 11:00 AM
Greg in France's Avatar
Almost for certain you need a new slave cylinder and a new master cylinder, or re-rubber-seal the old ones. It is not worth just doing one, the other will be close behind it, even if it works for now.
Old Jun 2, 2019 | 02:17 PM
orangeblossom's Avatar
Last edited by orangeblossom; Jun 2, 2019 at 02:20 PM. Reason: Text disappeared when I uploaded a Photo
Old Jun 2, 2019 | 02:27 PM
Hi Lee
When I uploaded the Photo above, all the Text disappeared!
but the Photo is of a Blocked Flexible Pipe from the Clutch of my MGB so might be worth Checking the Flexy Pipe to your XJS Slave Cylinder
Old Jun 3, 2019 | 07:06 AM
leep123's Avatar
Originally Posted by orangeblossom
Hi Lee
Thanks for persevering OB. I will certainly have a look at the hose as well. Didn't know you had an MGB. We did also for 12 years before the red mist descended and I bought the XJS. If only Jag parts were as cheap as MG!
Thanks also to Greg for his thoughts.
LeeP
Old Jun 3, 2019 | 08:23 AM
Hi Lee
Some XJS Parts are much cheaper than those for an MGB
Fuel Pump for instance: XJS about £33
MGB about £100!
milleniumaire
Oct 1, 2020 05:59 PM
MannyJag
Apr 18, 2016 10:17 PM
Gregfromuk
Oct 7, 2013 03:03 PM
03Xtype
Apr 10, 2013 12:07 AM
caimano
Apr 26, 2012 11:09 AM
