Help to rebuilod XJS calipers
Old Oct 23, 2018 | 04:25 PM
MIFoodie's Avatar
Unhappy Help to rebuilod XJS calipers
HI. I am trying to rebuild the XJS calipers myself and got all the way to inserting the square rubber piece in the groove of the piston and then adding the new stainless steel piston into the cavity. Unfortunately while I have the dust seal in place and fully down on the caliper I can't seem to get the retaining ring onto the dust seal without it coming off the caliper. What can I do ? Is there an easy way to put these retaining rings onto the dust seal?
I appreciate any help.
Old Oct 27, 2018 | 02:18 AM
Greg in France's Avatar
There is a problem with modern aftermarket dust covers. They are too thick for the calliper indentation. I found an NOS genuine Girling kit, and the dust covers went on fine, whereas the aftermarket kit covers would not. I have no ideas about fixing them; but maybe others have?
Old Oct 27, 2018 | 04:28 PM
warrjon's Avatar
I didn't have a problem when I did mine, they went on fine.
Did you use brake grease to assemble?
Old Oct 27, 2018 | 11:11 PM
MIFoodie's Avatar
I did use brake grease and they are now on fine. Thanks all !
nofking
Jul 14, 2018 08:49 PM
kenatofc
Feb 23, 2014 09:44 PM
icsamerica
Aug 2, 2013 01:07 PM
thuffner3
May 8, 2012 07:12 AM
thuffner3
Mar 25, 2012 12:03 AM
