Hose to No Where?
Old Oct 6, 2012 | 02:25 PM
Safari's Avatar
Default Hose to No Where?
My 89 XJS has a hose with no obvious connection point. The hose is located on the left side just under the coolant recovery tank (see pictures).
The hose looks like it was cut so I have no idea how long it was originally.
Does anyone know where this hose should connect?
Thanks!
Mark
Old Oct 6, 2012 | 03:49 PM
Per's Avatar
Per
Looks like part of the HOT START vacuum / electrical system. When the temp sensor under the front of the RH fuel rail sees 70C it will help apply full fuel pressure (3 Bar) to the injectors during start.
The hose is joined with a thinner plastic hose coming from the vac solenoid triggered by the tem sender mentioned above.
Old Oct 6, 2012 | 07:20 PM
Greg Edge's Avatar
That hose goes to your charcoal canister. The valve it is attached to is the canister purge valve.
Old Oct 6, 2012 | 11:10 PM
Safari's Avatar
Yes, you are correct. I followed the hose today and found it went to the charcoal canister. But where does the loose end go? Should'nt it connect the the airbox or some other place to draw the fumes into the engine? How else in the canister evacuated?
I find it hard to believe that was designed to lay in the engine compartment without a connection point or some kind of termination.
Old Oct 7, 2012 | 04:38 AM
warrjon's Avatar
It connects to the right of the air box. There is T piece one side goes to the LH airbox and the other side goes to the small pipe between L & R manifolds.
Old Oct 7, 2012 | 10:16 AM
Per's Avatar
Per
Interesting. Checked my Eurospec car yesterday and mine went to the Hot Start as stated. Do you have both then, using similar valve and hose setup for both?
Old Oct 7, 2012 | 12:16 PM
Safari's Avatar
Ahhhh...thank you for the info.
I'm sure my engine has been modified at some point so the T-fitting on my car is different than yours. The T is there but it is occupied with other hoses. (see photo)
Looks like I will have to add a new T in someplace so I can connect the charcoal canister.
Thanks!
Mark
Old Oct 7, 2012 | 01:37 PM
Per's Avatar
Per
Originally Posted by Safari
So what is this valve/T-piece in the cannister setup? It looks just like the vac delay unit in mine. It does not look like the usual purge control valve (solenoid actuated) and no wires that I can see?
Old Oct 7, 2012 | 03:09 PM
Safari's Avatar
If I am correct, when the car is not running, the Charcoal Canister traps fumes from the gas tank. When the engine is started the vacuum switch is opened and the fumes absorbed by the charcoal are drawn into the engine to be burned.
Mark
Old Oct 7, 2012 | 03:13 PM
Per's Avatar
Per
Mark
So purely vac driven then and not electrically as on later models? when did the change happen, the WSM is less than accurate regarding which market got which change when. (I haven't got my parts catalogue here which would probably be more accurate in this context.)
Old Mar 16, 2013 | 09:14 AM
wasislos's Avatar
Default Fuel rail sensor
Can anyone tell me what the name or model number of that fuel rail vacuum switch is in the upper right had corner. Thanks
Old Mar 16, 2013 | 09:32 AM
Doug's Avatar
The brown one? That's the fuel temperature switch
Old Mar 17, 2013 | 10:52 AM
wasislos's Avatar
Default Fuel Temperature switch
You wouldn't happen to know where I could get one? Maybe there is a replacement part that is not so fragile?
Old Mar 17, 2013 | 11:17 AM
Doug's Avatar
Google part # EAC5086 and see what comes up.
I suspect any of the usual Jag vendors can get one for you. Not sure if they're still available brand new but, if not, a good used one.
If used is the only choice then it'll be brittle. That's just what happens to plastic parts after years of engine baking :-)
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
