throttle potentiometer
Can anyone tell me if I adjust the pot to .036 and then I start car runs great for about 10 minutes then the reading goes to .01 does it mean that the pot is bad? When I disconnect the red wire the wiper it will run fine. Just dont want to throw parts at it but this seems to be the problem. Did a sweep test on it it did seem a little jumpy. Thanks for any help
Buzzaw (06-25-2018)
Greg in France (06-26-2018)
You should get somewhere between -0.3 to +0.3 volts (measure across the red and yellow leads).when the throttle is in the idle position. If not, adjust it until it is. When you rotate the throttle pot, it should max out about 5 volts when you reach the mechanical stop. This should be a smooth transition. If it "jumps" alot, has spots where the voltage doesn't change or otherwise acts strange, it's likely time to replace it.
Thanks,
John
Thanks,
John
Buzzaw (06-25-2018)
Check the 5v reference on the pot, which is the green and yellow wires this MUST be done with the pot in the circuit. The problem might not be the pot it might be the reference voltage from the ECU.
The TPS in the XJS as far as I can tell is there for closed throttle fuel cut and acceleration enrichment, the load is derived by the MAP.
Buzzaw (06-25-2018)
The following 2 users liked this post by Buzzaw:
Doug (07-02-2018),
leo_denmark (07-03-2018)
radarwhiz
09-21-2010 12:50 PM
