Idle air valve control
Old 01-11-2019, 08:57 AM
Softball60's Avatar
Default Idle air valve control
I just developed a new condition on my 1996 XJS. My idle started to go out of control. While driving and taking my foot off the gas it would idle up instead of going down.
I disconnected the idle air control valve to see if it functioned differently. It does.....it runs better!!!! What is going on?
It is a very cold day for Florida so whenI started it up this morning to see if it would even start without the idle control valve disconnected. It started right up...idle was a little hesitenty but with warming up it ran ok.
I adjusted the the idle mechanically after it warmed up good...600 w/brake in gear and 750 in neutral. It runs really well so I took it for a spin ~ 10 miles....No issues what so ever.
Can someone please explain this to me......
I did order a new idle control valve.
Thanks as always
Softball60/Paul
Old 01-11-2019, 12:47 PM
Jagboi64's Avatar
Received 3,056 Likes on 2,031 Posts
They can get carboned up and stick in various stages of the operating range.
When changing the valve, be aware that the small screws that hold it to the throttle body have loctitie on them, if you try and undo them you will break off the screws. Heat them with a microtorch before trying to undo them, the heat breaks down the loctite.
The following 5 users liked this post by Jagboi64:
kjopen (01-11-2019), Lawrence (01-31-2019), motorcarman (01-13-2019), petemohr (01-12-2019), Softball60 (01-11-2019)
Old 01-13-2019, 07:14 AM
Softball60's Avatar
Well it has been several days and I have been driving without the idle control valve connected.
Other than the initial warmup with the higher rpm the jag has been running great.
I am a little confused that not one engine failure light has gone on. Is this more of a auto chocking device and possibly to eat out another 1/10th of a mpg?
My new unit will be here in a couple days.
Your insight is appreciated.
Softball60/Paul
Old 01-13-2019, 08:53 AM
Vee's Avatar
Vee
Vee is offline
Received 1,510 Likes on 1,176 Posts
The 96 is reluctant to throw out codes for much of anything. Jag had just entered the OBD2 world and didn’t get good at it until later on.
Basically, if you have a code, it helps you find the problem, but the lack of a code shouldn’t cross off any potential failure that a code would normally shed light on.
The following 2 users liked this post by Vee:
Doug (01-13-2019), Softball60 (01-13-2019)
Old 01-13-2019, 10:54 AM
Jagboi64's Avatar
All it does is add extra air when cold. The engine will be fuelled according to look up tables when starting and cold, so it won't save any fuel to leave the idle air controller disconnected. All you do is lose control over the warmup idle speed!
Old 01-13-2019, 11:49 AM
Vee's Avatar
Vee
Vee is offline
Not true. The idle air control valve will manage the volume of air entering the warm engine when the car slows down below 3mph.
A misfunctioning IACV can create all sorts of havoc when the car is near or at idle.
Old 01-13-2019, 02:43 PM
Softball60's Avatar
Vee,
What type of havoc are you refering to?
I have driven without the IAC not connected for ~ 4 days....Not one (1) issue
Softball60/Paul
Old 01-13-2019, 11:03 PM
Jagboi64's Avatar
Depending on where the idle speed plunger stuck, there is always the possibility of stalling when in gear and the AC compressor engages.
Softball60 (01-14-2019)
Old 01-14-2019, 08:32 AM
Vee's Avatar
Vee
Vee is offline
Malfunctioning IACV causes havoc. Disconnected IACV results in overfuelling since the car must assume the amount of air coming into the engine.
After replacing the IACV, you'll likely need to have the TPS reset, which needs to be done with someone that has access to Jaguar specific software. The dealer will always have access to that, fewer independent shops will as well. That's been the case with my AJ16 engined cars. Everytime I swapped out the IACV, the idle ran high until the TPS was reset.
Old 01-14-2019, 06:44 PM
Softball60's Avatar
There is a manual method for adjusting. I have used it once before and it worked.
Softball60/Paul
Old 01-14-2019, 08:08 PM
Vee's Avatar
Vee
Vee is offline
That manual readjustment might work on an AJ6 engine, but it will not work on the AJ16. The reset works, until you shut the car off and then whatever the manual reset did is lost and forgotten.
Softball60/Paul
Softball60 (01-15-2019)
Old 01-15-2019, 06:03 AM
katar83's Avatar
Vee, its not exactly true, TPS adaptation has nothing to do with IACV, nothing re IACV is stored in ECU and after replacing IACV you don't need to reset TPS. In a perfectly tuned up engine disconnecting IACV will cause slight drop in mpg and occasional stalling, especially when getting to a stop and are in eg 3rd gear, AC kicks in and RPM will drop and might cause a stall. It all depends on butterfly gap and how throttle body closes though so some engines where the gap is bigger than what it should be or doesn't fully close due to gunk or stretched linkage will run just fine with IACV disconnected and in fully closed position as the extra air needed to run engine will go through the butterfly gap.
All that is needed to get IACV in fully closed position on AJ16 engine is to cycle ignition few times, generally when you switch off the engine the iacv should extend itself, then go up a little, so next time you fire it up IACV is already in partially open position and allow a bit extra air on possibly cold startup. You can always connect a spare IACV, hold it in hands(to prevent plunger shooting out of the IACV) and have someone turn ignition key two position 2, wait few seconds and go back to 0 and wait again, this should explain best how it works and how to get it fully extended so when after replacing it you shouldn't have any high idle problems.
Hope that makes sense!
The following 2 users liked this post by katar83:
petemohr (01-15-2019), Softball60 (01-15-2019)
Old 01-15-2019, 06:25 AM
Vee's Avatar
Vee
Vee is offline
Katar83,
While on paper this may work, my experience has been otherwise. I spent a good amount of my life chasing down TPS and IACV problems. Eventually, after paying Jag specialists a few times for a reset, I found my own WDS and ended that! (Now I also have a PDU, I just don't have cables for any Jaguar vehicle without an OBD2 port!)
Anyways, I agree that changing the IACV should have nothing to do with resetting the TPS, yet for some reason, everytime I have replaced an IACV, a TPS reset seems to be in order. A manual reset of the IACV seemed to fix the idle, but only until the engine was shut off.
As for manually resetting the TPS, that indeed can be done too. I forgot about that. Slotting the two bolt holes so the TPS can be adjusted, while on the throttle body, with the car idling, you can slightly adjust the position of the TPS so that it idles correctly, then you can lock it in. There are indeed threads on that too.
Old 01-15-2019, 07:08 AM
Softball60's Avatar
I want to thank all of you for the latest responses. My original thread started off slow, I thought no one was interested...boy was I wrong.
The new IAC should arrive today. Will let you know!
Softball60/Paul
Old 01-20-2019, 10:35 AM
Vee's Avatar
Vee
Vee is offline
I'm hoping you'll come back and wrap this one up for us.
Softball60/Paul
Softball60 (01-20-2019)
Old 01-20-2019, 06:55 PM
Softball60's Avatar
As a matter of fact received the IAC yesterday and installed today. A couple of trips and all. Is well. Idle in gear 600rpm and in neutral 750.
When initially started it starts out @ ~ 1100rpm and idle’s down to 750.
Everything is good!!!
Thanks to all for their involvement.
Softball60/Paul
Old 01-20-2019, 07:01 PM
Vee's Avatar
Vee
Vee is offline
Excellent! Happy to hear it went well.
On a related issue, perhaps my TPS was bad longer than i thought since I was chasing down a high long term fuel trim that was resolved by replacing my TPS with a new one. Maybe when i replaved my IACV, it uncovered the failing TPS which was then band-aided when i reset it using a WDS.
I learned something here. Thank you.
Softball60 (01-21-2019)
Old 01-21-2019, 07:29 AM
Softball60's Avatar
For back yard mechanics like myself, it sometimes takes a lot of trial and error. I have come to learn two (2) things;
1. When the idle is all over the place high and low it is usually the IAC.
2. When it does not want to take off from a standstill idle it is the TPS.
I am proud to say that other than installing tires/etc. NO ONE has touched my car for any repair but Me!!!!
It is not so much how good you are, but taking advantage of all the resources available, ie; Jaguar Forum, U-Tube, etc.
It is just great having these kinds of discussions!!
Thanks as Always
Softball60/Paul
Old 01-24-2019, 12:48 PM
Softball60's Avatar
For those who wanted an update, it’s been ~ 1 week and all is good.
Softball60/Paul
Old 04-30-2020, 09:02 PM
Magnusandthor's Avatar
Default 1990 xjs iacv
Seems this part is no longer available. Does anyone know of a replacement from another model that will work or a rebuild/cleaning procedure?
Quick Reply: Idle air valve control
