Indicator unit repair
Old Dec 1, 2013 | 02:40 AM
warrjon's Avatar
Default Indicator unit repair
While I had the column apart I thought I may as well fix the broken clamp that hold the indicator unit steady on the column.
This is a common problem and is easily repaired. I made a bracket from 1mm panel steel and screwed it to the plastic ring. I used the dremel again to remove the end of the screw inside the plastic ring.
Once screwed in place it does not move around anymore when using the wipers or indicators
Attached Thumbnails Indicator unit repair-dscn0630_zps981693ba.jpg   Indicator unit repair-dscn0632_zpsd2cb3fc1.jpg   Indicator unit repair-dscn0633_zps325453fa.jpg
trosty
26
Dec 18, 2022 06:40 PM
skyryder
Mar 25, 2016 08:18 PM
1LowCat
Sep 14, 2015 07:51 PM
al_roethlisberger
Sep 7, 2015 10:53 PM
Mosers63
Sep 6, 2015 02:53 PM
