Injector pulsing what voltage
Old Sep 25, 2019 | 11:58 AM
anyoldiron's Avatar
Banned
Default Injector pulsing what voltage
Hello Sportsfans!
l Have a 1982 V12 XJS , im doing the injector rubber rebuild. l want to cycle the injectors what voltage/type of battery do i use?
Cheers AOI
Old Sep 25, 2019 | 12:58 PM
ronbros's Avatar
what is a sportfan?? is it for cooling?
12 V recommended,, what are you going to use for a pulse,,(on/off rapidly and adjustable rate), also be able to adjust the fuel pressures.
a machine that does it all for you! even measures the final volume with all injectors, by CCs!
Old Sep 25, 2019 | 06:09 PM
anyoldiron's Avatar
Banned
The Sportsfan is only available in the US and on the very limited ''Santini'' edition.
Yeah, i just wanted to pulse them, used a 9v torch battery in the end.
Cheers AOI
DerekPrice
Mar 14, 2018 02:30 PM
orangeblossom
Feb 5, 2017 09:27 AM
layada
Jan 10, 2017 02:18 PM
Per
Jun 25, 2015 08:40 AM
M90power
Mar 24, 2012 08:35 PM
