Instrument panel brake light is on
Old Jul 4, 2023 | 11:18 PM
jomo's Avatar
Default Instrument panel brake light is on
Hi,
I am a bit confused about the instrument panel lights associated with the brakes on my 95 XJS. My brake light is on. What does this mean? The reason I ask is because based on what I read along with my not completely understand what I read, I think that there are two instrument lights for the brake system.
Can someone please tell me what they both do? I think one is for the abs system and the other light is just for brake fluid level(?)
Old Jul 5, 2023 | 05:49 AM
Vee's Avatar
Vee
There is a yellow ABS light and a red BRAKE light.
If it’s the red one, I would start by checking the brake fluid level.
After that, you’ll probably want to take it into a shop.
Old Jul 16, 2023 | 02:23 PM
jomo's Avatar
The issue turned out to be a bad float in the reservoir cap. I remember Greg in France once saying that could be the trouble. I simply swapped the cap with the one on my 95 xj6 and the light went right out. I only hope that the brake light doesn't come on in my xj6. If it does, at I know what the problem is!
Thanks,
Jomo
burton512
May 31, 2022 09:13 PM
garethashenden
Oct 20, 2020 01:07 PM
xjrjag
Sep 24, 2015 10:08 PM
Mikeamalfi
Apr 2, 2012 05:29 PM
cadfael_tex
Jul 28, 2011 04:04 AM
