Jaguar Stalls and Tranmission light comes on
Old Jul 3, 2018 | 07:24 PM
stellarentertainment1's Avatar
Unhappy Jaguar Stalls and Tranmission light comes on
Hey Guys! Need some help here.. my 95 Jaguar XJS has started spontaneously stalling like it is receiving no fuel. When it happens, the transmission warning light comes on and the car goes into limp mode. I can shut it off and restart it and it will be ok again for awhile until it reoccurs. I thought maybe fuel pump or ECM. Any suggestions?
Thanks,
Paul
Old Jul 4, 2018 | 01:29 AM
orangeblossom's Avatar
Hi Paul
What sort of Car have you got?
V12 or 4.0L ? Please would you add that to your Signature so we can try and help you more, the next time a problem crops up
Old Jul 4, 2018 | 07:34 AM
Vee's Avatar
Vee
I’m assuming there’s no check engine light illuminated? (I’m also assuming it’s the 6 cylinder engine, but please add a signature for future reference)
I’m not sure whether an OBD2 reader works on your car or not.
The transmission light is likely the by product of the stall and has nothing to do with finding the cause.
The biggest common culprits are as follows:
1. Throttle Potentiometer Sensor
2. MAF Sensor
3. Coolant Tempersture Sensor
4. Downstream Oxygen Sensors
5. EGR Sensor
#3 is the cheapest to replace, but also cheap to diagnose. Unplug it and jump the two pins at the harness, not the sensor, and drive. If it happens again, it’s not the #3.
#5 can be cleaned apparently. I’ve never had luck with that and ended up spending the $100 or so on a new one. My engine would stall, like yours, then one day it reluctantly kicked me out a code and replacement cured the issue!
The others require multimeters for testing. There’s plenty of info on testing these components on this forum.
Old Jul 4, 2018 | 07:42 AM
It is a V6 4.0 liter. Ok this is great information. I'll get started on narrowing those out. I think it does have a OBD2 reader port but I just figured it was a bigger problem then a sensor. Thanks! I'll change the description of my signature soon.
Old Jul 4, 2018 | 07:44 AM
Vee's Avatar
Vee
While you’re at it, you have an in-line, or I6, not a V6.
Old Jul 4, 2018 | 02:32 PM
ptjs1's Avatar
stellarentertainment,
When was the fuel filter last replaced? I've seen very similar symptoms on an XJS with a very old filter that couldn't properly flow fuel. Turn off ignition, start again, pump powers up and runs ok until restriction happens again.
Good luck
Paul
Old Jul 5, 2018 | 07:38 AM
Vee's Avatar
Vee
I also forgot to mention
6. Dirty throttle body.
Easy to clean, but I recommend taking the throttle body off for a thorough cleaning.
Bstaronline
May 13, 2018 03:42 PM
jvickers
Nov 19, 2012 02:04 AM
lewisc911
Jun 10, 2011 07:28 AM
mosdef
Feb 11, 2010 09:10 PM
JRG-XJR
Aug 9, 2009 10:43 PM
