Knock off hubs
Old Mar 27, 2026 | 09:32 AM
Speedster's Avatar
Default Knock off hubs
I am building a Race Car/ Speedster using a 1986 XJS rear independent suspension. It currently has the 5 stud hubs. I want to convert it to knock off hubs. Is this possible to convert this unit to knock off hubs? If yes, I'm looking for correct part number and or supplier for these hubs. Thank you. Speedster in Michigan
Old Mar 27, 2026 | 11:00 AM
garethashenden's Avatar
I don?t know this for certain, but I would be inclined to think E-type hubs could be used. They were available with knock off wheels and it?s basically the same IRS. The track width is different, but otherwise I think they?re really close.
Old Mar 28, 2026 | 09:15 AM
motorcarman's Avatar
Contact Dayton. Maybe they have all the parts?
https://www.daytonwirewheels.com/wir...cessories-caps
Old Mar 28, 2026 | 10:56 AM
davchr's Avatar
SNGBarratt.com has front and rear splined knock off hubs for early Jags. They may or may not fit an XJS.
Rear RH P/N C20889
Rear LH P/N C20890
Front RH P/N C19225/1
Front LH P/N C19226/1
Old Mar 28, 2026 | 11:29 AM
Jagboi64's Avatar
The hubs will work, it should be a straightforward swap of the hubs.
You will need to set up the bearing preload with appropriate shims, but that is the same procedure for all IRS rear ends, so plenty of information over at Jag-lovers in the E Type forum about how to do that.
Last edited by Jagboi64; Mar 28, 2026 at 11:37 AM. Reason: Mistread the OP post as 1996 IRS
Old Mar 28, 2026 | 06:41 PM
Speedster's Avatar
Thank you for info, I knew it was out there somewhere. I'm headed over to Jag-lovers. Speedster
Old Mar 28, 2026 | 08:45 PM
Jagboi64's Avatar
Here is the setup from a 1985 manual:
electrovolt
Dec 8, 2025 08:34 PM
David N. Warner
Jun 28, 2022 01:27 PM
jagrodrigues
May 27, 2021 05:21 AM
Hawkeye
May 4, 2009 08:28 PM
