Leak from 4.0 Autobox dipstick tube
Old Mar 10, 2024 | 04:40 PM
Vee's Avatar
Vee
Its the popular ZF 4HP24 transmission....wouldn't they all have similar dipstick parts?
I also think you would be able to find a used part rather easily?
Old Mar 10, 2024 | 04:41 PM
Vee's Avatar
Vee
Does it look like this:
​​​​​​https://www.ebay.com/itm/17621136518...Bk9SR8i9-qTFYw
Old Mar 10, 2024 | 04:50 PM
ptjs1's Avatar
Hi Vee,
Unfortunately, they all seem to be different. Even the XJ saloons with the same engine and gearbox have a completely different shaped tube.
I can't find the exact one on eBay etc. And with that annoying 90 degree join, where I seem to have the drip leak, I'm not sure I'd trust a used item.
I think I'm going to try and solder mine.
So, a word of warning to everyone when you next change your filter, be careful not to stress that 90-degree join in the dispstick tube!
Paul
Old Mar 11, 2024 | 05:45 PM
ptjs1's Avatar
Tonight, I decided I really had to get to the bottom of exactly where the leak was coming from.
After cleaning off the join at the bottom of the dipstick tube, I used a wirebrush wheel to remove the paint. I could then see that the 90 degree joint had originally been brazed. But even with a magnifying glass, I couldn't see a split in the brazing.
So I stared through the magnifying glass for 5 minutes and then, Eureka, I worked out where was the problem! There was surface corrosion near to the join and one tiny little pinprick had broken through the surface of the tube from which the tiniest smear of fluid slowly started to escape. I've highlighted it in the second photo.
It's almost unbelievable that a pinprick almost invisible to the naked eye, could cause this leak. It just goes to show how ATF can escape through the tiniest of imperfections.
So, tomorrow, I'll mask off, clean up the whole area more thoroughly, and then quickly smear the whole of that area with some Evostick epoxy metal putty which should seal it nicely, before painting it.
Hopefully that will be the end of a frustrating 2-year quest to stop a persistent drip!
Paul
Old Mar 12, 2024 | 03:56 AM
Greg in France's Avatar
Paul
I would use a liquid high temp epoxy glue, like araldite, I am not sure epoxy metal putty will really get into that hole. Good luck and good find, anyway!
nilanium
Nov 2, 2025 10:23 AM
RacingGreen87
Oct 5, 2022 03:12 PM
MK2 1962
16
Oct 15, 2021 03:50 AM
crbass
Dec 3, 2020 08:01 AM
The Coupe
Aug 4, 2020 07:22 AM
