looking for NEW brake booster , 1978 XJS
Old May 10, 2018 | 06:17 PM
ronbros's Avatar
Default looking for NEW brake booster , 1978 XJS
who would have for sale , a NEW vacuum booster unit for 1978 XJS?
found some used !
i prefer a new one , not used ,rebuilt, refurbushed , overhauled etc.
is there such a thing and how would i know for sure its history!
my car is showing its age , booster was new in 1993,BUT time marches on!
some Jag parts sellers show the early XJ6- and XJS are the same? like 1989 was a change area!
ron
Old May 10, 2018 | 08:22 PM
icsamerica's Avatar
I recently got one from RockAuto. It was A-1 CARDONE 535950 It's working great, appeared new.
If you want an upgrade... I've got a composit pedal box,booster and master from 1995 XJS I've retrofitted to a 6 speed.
Old May 11, 2018 | 12:32 AM
orangeblossom's Avatar
Hi Ron
Have a look at this one
https://www.jaguarclassicparts.com/u...aster-cylinder
Old May 11, 2018 | 12:49 AM
Hi icsamerica
The Brake Pump on my 1990 XJS pre-facelift 5.3L has burnt out and a New one is NLA
How easy would it be to retrofit a composite pedal box booster and master from a 1995 XJS (was it from a 4.0L or from a V12)
Do you have any Pics of the unit and how you fitted it, so I can see what is needed and what it looks like
Here is a Link to the Problem with the Brake Pump on my V12 https://www.jaguarforums.com/forum/x...122634/page86/
Old May 11, 2018 | 12:53 AM
Hi Ron
I think that TRW 'may' do a New Brake Booster for an XJS that might be worth checking out
TRW 64049746
Old May 11, 2018 | 04:51 PM
xjsv12's Avatar
I
I was upgraded from XK8 2003.Pedal box, assembly with aluminium master cylinder. Directly fit. But I was have a problem with the triangle reservoir.
The price will today is comparable to the new booster.
The difference between the right and left steering is only a hole for vacuum. For LHD is JLM10735 and CAC1227. RHD is JLM10734 and CAC1226
Old May 11, 2018 | 06:34 PM
icsamerica's Avatar
Originally Posted by orangeblossom
Hi icsamerica
Composit pedal assembly is a bolt in. Fluid line might be in a slightly difftent location. Switch for stop lamps would have to be improvised.
I've driven both early, mid and late XJS. The early and late vacuum brakes feel great. I have no-idea what Jag was thinking with that Teves system with the accumulator. The pedal feel, or lack of pedal feel, is not suitable for a proper GT.
Old May 11, 2018 | 11:15 PM
Hi icsamerica
Funny you should say that, I was thinking the same thing
The vacuum brakes on my old Merc feel about 10 times better than those on my XJS which unlike the Merc seems to lack 'Pedal Feel'
Was your composite pedal box booster from a Six Cylinder Car of a V12 ?
Old May 12, 2018 | 07:25 AM
xjsv12's Avatar
found some used !
ron
https://www.sngbarratt.com/uk/#!/English/parts/6a12aba7-62ec-443d-84d6-2e46679173e0
Old May 12, 2018 | 10:19 AM
Doug's Avatar
I've found that weird pedal feel on many 80s vintage cars with ABS....probably because Teves supplied so many manufacturers. But, same applied to the early Bosch systems.
I'm a big fan of ABS but those early systems left a lot to be desired; lots of consumer complaints. The early 90s GM ABS systems were terrible, IMO. Much too over-active/agressive
Things have gotten much better
Old May 14, 2018 | 05:34 PM
ronbros's Avatar
ordered a vacuum brake booster, WELSH JAGUAR, on its way!
best price i could find,in stock!
mark1210
Nov 1, 2017 11:41 PM
themon
Jul 21, 2017 10:15 PM
dweidmann
Aug 28, 2015 05:30 PM
kfishalaska
Dec 11, 2014 07:17 PM
Palmero
XJ40 ( XJ81 )
Jan 23, 2013 11:38 AM
