Looking for XJS Specs
Old May 30, 2008 | 08:37 AM
porschegonzo's Avatar
Default Looking for XJS Specs
ive been trying to find some more info about this car and have had very little luck. does anyone have a link or a site that gives the specs (performance and/or stuff like whether or not it has limited slip, general maintenance info like how much oil this thing takes)
thank you
Jeff
Old May 30, 2008 | 10:25 AM
ken@britishparts.com's Avatar
Default RE: Looking for XJS Specs
Need more info. Start with what year is it?
Old May 30, 2008 | 10:35 AM
its a 1985 XJ-S with the V12
Jeff
Old May 30, 2008 | 11:51 AM
still trying to get it to start. motor is turning but not as fast as it should. is there a good and easy way to check for spark?
Jeff
Old May 30, 2008 | 03:35 PM
I don't think slow cranking would have anything to do with spark. Have you checked the starter?
To check sparg, pull a spark plug and check like any other car. Don't zap yourself. That never feels good.
Old May 30, 2008 | 03:38 PM
im going to check for spark a little later but it is a posability that the fuel pump isnt working. the owner didnt mention it, but in the trunk there is a new lucas fuel pump still in the box.
Old May 30, 2008 | 06:10 PM
mghirsch's Avatar
If the starter is turning slowly, it might be due to a bad ground between the engine and the frame. Try running an auxillary ground.
Old May 30, 2008 | 06:28 PM
i tried running arother ground wire and its doing the same thing. i think the problem is the main battery in the car is long gone, and will not charge, so im trying to jump start the car and i dont think the porsches alternator is strong enough to do it. i need to go buy a real battery and be done with it
aholbro1
Dec 29, 2024 06:46 PM
jjlu2
Jan 29, 2016 07:02 PM
duecedriver
Dec 25, 2015 11:47 AM
scooternva
19
Oct 27, 2015 02:14 PM
mrplow58
Sep 15, 2015 09:58 PM
