Loud "ticking" or "clacking" at startup
Old Sep 18, 2012 | 08:23 AM
meeither's Avatar
Default Loud "ticking" or "clacking" at startup
Well, everything worked perfect for a day or two :-).
On cold start up, loud "ticking" noise (not a lifter), almost sounds like metal "clacking" on metal, but isn't. Only does it first start, will not do it if I start, shut down, and re-start. Runs great once it starts.
Might even be arcing in ignition, but I do not have a clue at this point. Anyone have a guess?
Old Sep 18, 2012 | 08:36 AM
Greg in France's Avatar
? model; ? engine: ? year
Old Sep 18, 2012 | 10:53 AM
Flint Ironstag's Avatar
Checked your oil level?
Old Sep 18, 2012 | 12:16 PM
meeither's Avatar
10.5 fresh new was mate.
Old Sep 18, 2012 | 12:19 PM
meeither's Avatar
stops the very split second engine starts. Only makes noise while turning over to start.
Old Sep 18, 2012 | 12:22 PM
meeither's Avatar
Originally Posted by Greg in
France;583338
92, 5.3,xjs
Old Sep 18, 2012 | 01:41 PM
Sarc's Avatar
So if you disconnect the fuel relay (forcing a no start) will you get the noise continually as long as the starter is cranking ?
Old Sep 18, 2012 | 08:57 PM
meeither's Avatar
Thinking it may be the Bendix not engaging fully. Will check that this weekend and let everyone know if that is it.
Old Sep 19, 2012 | 07:01 AM
A tooth missing from the ring gear (not so common).
The Bendix is slipping (sort of common).
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
redxk8
Oct 4, 2015 08:28 AM
baskervillema
Oct 1, 2015 06:43 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
