Low beam headlight not working
Old May 1, 2019 | 04:04 PM
Whatcher3's Avatar
Default Low beam headlight not working
Greetings,
Discovered the left side low beam headlight does not light up. However, when I switch to high beam all 4 lights are on. What!! Anyway, I checked the fuses. All are good. So any tips about what to test next are welcome.
ok, this is on my 1990 XJS V12 Convertible.
Old May 1, 2019 | 04:20 PM
warrjon's Avatar
It has to be one of the following.
- Fuse 4 in the black fuse panel in the engine bay
- Connectors on fuse 4 or to the low beam lamp
- Faulty low beam lamp.
According to the electrical guide there are 2 bulbs one is high beam only and the other dual high/low beam when high beam is on low is off what you are seeing is the high beam part of the dual bulb.
Old May 1, 2019 | 06:43 PM
mghirsch's Avatar
The low beam bulb has two filaments. I believe that the low beam filament is burned out. Try replacing the bulb.
Old May 1, 2019 | 06:57 PM
Whatcher3's Avatar
Thanks. I’ll test the bulb itself.
awil
Mar 23, 2015 06:35 AM
hawaiiboyy
Apr 13, 2014 04:44 PM
cybercg
Sep 30, 2013 03:43 PM
perezrp101
Feb 3, 2009 10:25 PM
Jan 2, 2007 04:37 PM
