Lucas ignition years - What type of connectors for the fuel injectors
Old Mar 30, 2023 | 06:25 PM
alabbasi's Avatar
Default Lucas ignition years - What type of connectors for the fuel injectors
I have a 90 XJ12 but the ignition system is the same as the pre 89's. Does anyone know what type of injector connectors used? I bought Bosch EV1's but they don't fit and click on.
Old Mar 31, 2023 | 04:04 AM
Thats the Bosch Part # for the kit.
What I have used for 30+ years.
I used to buy direct when I had my Parts Store, but now I have no idea, the Store is gone as are the V12's.
Google could be your friend.
There will be alternatives, but I dont know them.
Old Mar 31, 2023 | 06:17 AM
Doug's Avatar
Google "Bosch Injector Connector EV1" and you'll get lots of hits
Old Mar 31, 2023 | 09:15 AM
Greg in France's Avatar
Makke sure you buy then ones with the half moon cutouts, otherwise they do not fit:
Old Mar 31, 2023 | 04:27 PM
alabbasi's Avatar
Thanks, I bought EV1 connectors but they don't fit. I'll order a different set from someone else.
Old Apr 9, 2023 | 04:30 AM
FerrariGuy's Avatar
Only the low profile EV1 type connectors will fit. E.g.
TE PN 825414-5 or
826008-5
AMP
TE Internal #: 826008-5
Timer Connector System, Housing for Female Terminals, Wire-to-
Wire, 2 Position, 5mm [.197in] Centerline, Sealable, Black, Signal
~Paul K.
File Type: pdf
File Type: pdf
Old Apr 9, 2023 | 08:29 AM
alabbasi's Avatar
Thanks, that is the challenge. The angle of the injector terminal makes it impossible to latch.
Old Apr 9, 2023 | 12:11 PM
The connectors with the half moon cutouts are required. As in the photo in the second link we were posted by F G, and not as in the photo in his first link.
Old Apr 9, 2023 | 02:17 PM
alabbasi's Avatar
@Greg in France
That's what I bought initially, they work great on sensors but not on the injectors themselves. They may work on the new injectors that I'm getting
Old Apr 9, 2023 | 07:29 PM
FerrariGuy's Avatar
Greg made a good point about the cut out. Here are snips from the TE PDF as well as drawings for "maybe" a couple of alternate connectors including a knock-off version that looks easier to disconnect (IF it fits)The
The numerical -# variations tend to indicate different plastic colors.
Unknown if the cutout below is big enough:
PN 037 906 240G below for AMP connectors - By KingKong connectors (unknown fit but looks plausible)
Also PN 829441-1 looks the similar.
Old Apr 9, 2023 | 09:45 PM
Doug's Avatar
I never knew that EV1 connectors were high or low profile. Learn sumthin' new every day !
I guess I've just been lucky in always getting ones that fit fine.
santacruz11
Aug 17, 2022 07:25 PM
ransho
Jul 7, 2022 07:54 PM
doorjok
26
Aug 8, 2021 04:42 PM
layada
Jan 10, 2017 02:18 PM
Per
Jun 25, 2015 08:40 AM
