Manual Trans Swap - is it worth it?
Old Dec 9, 2024 | 07:52 AM
mouserider's Avatar
Default Manual Trans Swap - is it worth it?
Hi everyone,
I often feel like our beautiful V12 is being held back by the automatic transmission. I've always wondered how it would perform with a manual swap. From what I’ve seen, it’s a $10k+ project using the simply performance TREMEC kit.
Does anyone here have experience with this kind of conversion? Is it truly worth the investment in terms of driving experience and performance? I'd love to hear your thoughts!
Old Dec 9, 2024 | 08:59 AM
icsamerica's Avatar
I've manual swapped all kinds of cars including Jag V12's and Supercharged inline 6's and all sorts of LS and SBC V8's. Yes, worth it to me, nothing beats a V12 and a manual. The v12 manual experience is one of most impactful experiences an Auto enthusiast can have.
It's not all wine and roses though, getting the right shifter and clutch action / feel and having it all work as a smooth and congruent experience is harder than it seems. After the manual swap, if done well... it will make the rest of the XJS fall apart, the suspension is too soft, the engine has no sound and doesn't 'rev or inspire above 4500 RPM and the brakes turn to mush after even short performance driving stints. The steering will feel vague when faced with the contrast of a modern and precise shifter. People often wonder why Jag didn't offer the V12 XJS as a manual from the factory, seems like a logical and fair question leading to a missed opportunity, but after the swap the answer becomes clear, the rest of the car falls apart. So if you go down this road you have to look at the swap as a complete vehicle system with consideration given to the other aspects too. Plan accordingly for suspension, wheels tires, exhaust, engine and chassis tuning is the form of firm bushings, rear IRS bracing etc.
Is it worth it for you? Only you can answer that. Figure on 10k and 1 year of work being a good starting point. 20k and 2 years even as a DIY project is easy to get to. What V12 manual semi custom and tailored to your needs could you buy otherwise for that price. The answer is none. V12 manual Astons, E-types, Ferraris, and BMWs will cost a multiple of that but if well cared for will appreciate. The converted Jag most likely wont appreciate all that much if at all.
Old Dec 9, 2024 | 10:33 AM
Jagboi64's Avatar
They did, they made 378 of them, I believe the last one was in 1978. The reason it was discontinued was it didn't sell, much as the later cars with the 6 cylinder and 5 speed in 1993-4 didn't sell well.
Enthusiasts seem to like the idea of a manual, but don't buy enough of them new to make it financially viable for a manufacturer to make.
Old Dec 9, 2024 | 09:54 PM
nickr76's Avatar
Fall apart? I dont think so.
as long as you swap a mechanically sound xjs, its not going to fall apart simply because it is manual.
mine has a tkx, its great, drives beautifully. looks like it came like this from the factory. Totally different driving experience than the boring 3 speed, the auto handicaps the car.
it is a heavy car though, could use another 100hp
is the swap worth it? 100%
Old Dec 9, 2024 | 10:37 PM
Jagboi64's Avatar
For my tastes, if I was doing a transmission swap I would put in one of the 8 speed ZF automatics, rather than a manual. I have the ZF in my XF and it's a great transmission.
Old Dec 10, 2024 | 06:25 AM
asingleton's Avatar
Default Yes yes yes
Originally Posted by mouserider
Hi everyone,
For me, the only reason I purchased my 1985 V12 XJ-SC was because it had already been converted.... 5 speed manual Getrag. I LOVE IT! Mind you, my car has had a number of TWR modifications... TWR larger throttle bodies, TWR exhaust, TWR suspension kit with uprated springs and dampers, steering with less power assistance, etc. Did I say I LOVE IT!!!
Old Dec 10, 2024 | 07:40 AM
Mguar's Avatar
Hi everyone,
That price is massively higher than they cost me. But I’m a DIY guy. Plus I’m A vintage sports car racer.
My current project has a 5 speed ( no overdrive) so the gear ratios are very close together. That allows me to switch gear ratios very quickly.
The car goes into the pits up on stands, I pull the rear plate off and slide the gears out. Choose which gears I want for the track I’m on. Slide them out and change which gears work better. Slide them back in, put the rear plate back on, refill the lube and 15 minutes after you arrive in the pits you’re ready to go back on track.
It’s a dog ring, designed to shift without the clutch. Throttle only.
Old Dec 10, 2024 | 08:07 AM
Doug's Avatar
I don't think ISC is saying the car will literally fall apart. I think he means the the increased performance will bring out weak spots elsewhere. That is, other areas that need upgrading to match the new performance.
And I agree.
But....it would depend a lot on just how fast you drive and just how hard to press the machinery.
Old Dec 10, 2024 | 04:14 PM
nickr76's Avatar
I think you have to be realistic. These are cars that were designed in the 70’s
it will never drive like a modern car. It is as good(or bad) as other cars of this era.
but with a manual, it is much more enjoying to drive.
Old Dec 10, 2024 | 10:41 PM
icsamerica's Avatar
The XJS 'could' drive like a much more modern car with thoughtful upgrades to all systems. The fundamental's like good suspension geometry and a rigid chassis are there. This is not the case for other GT cars of the time. The problem is when you total up the time and money involved it just starts to make sense to choose a more modern 6 speed manual GT car so long as you don't 'need' that manual V12 experience. If you need the V12 manual experience and love the form of the XJS then upgrading all the other systems it's worth while.
Modern Transmission like the TKX shift with such clarity, precision and authority that it would quickly create mechanical dissonance with the rest of the XJS and it's designed in squishiness or lower levels of precision. Some enthusiast may not be bothered by this but some (many) would. The older 90's T5's and Getrag 265's were / are lot less precise and were a fine companion for the XJS as it was.
The 5.3 V12 if well tuned approximates 90% of the torque and power of the much more modern 5.3 LS. They're basically the same until 5000 RPM where the LS keeps building power for another 800 RPM. One could get the XJS to stretch and hang in there another 400 RPM with a free'r flowing exhaust.
The XJS suspension is very capable with some upgrades like those done to the DB7 which are mostly stiffer shocks and springs, stiffer bushing with shoulders and chassis braces. All difficult to apply as nothing off the shelf is available. The fundamentals of good suspension geometry haven't changed all that much since the 70's and the XJS suspension can be modernized but it will take creativity, time and money. Jag understood and applied these fundamentals very well at the time the XJS was developed becasue of their extensive success in racing during the 20 years prior. Case in point...., Consider the 2004 Aston Martin DB7 GT and it's still respectable 8:41 Nordschleife time. That was better than many full sports cars of the day. The suspension on that DB7 GT car is an slight evolution of the suspension in the XJS. You'd have to look hard to find the differences. Tire technology has continued to evolve considerably and I believe with modern tires that Nord'Ring time would be 30 seconds lower. DB7 GT or Vantage used the TR6060 and by all accounts was mechanically cohesive.
Brakes are also a difficult problem to solve as there's nothing bolt on for a XJS except for uprated pads and out board brakes from later XJ. Both would help greatly and reasonably practical to do.
Old Dec 11, 2024 | 12:20 PM
Jaguaralfonso's Avatar
Congratulations. It is one of the most sincere and consistent testimonies I have read.
Accelerating faster and better is very satisfying. That the slippage that the gearbox brings with the stock car disappears and changing when the maximum torque is reached is a great feeling.
But... driving sportily and taming a v12 engine in a vehicle that behaves like a boat is another story.
Perhaps after trying the experience of improving thrust, there will be more enthusiasts who take the step of converting a passenger car into a car with more racing temperament than the original one.
Lived, the XJS is a sensational car
Old Dec 11, 2024 | 10:53 PM
nickr76's Avatar
I have a TKX in mine, I was definitely one of the first to do this(has anyone else installed one yet?)
The TKX works very well.
like i said earlier, make sure your car is in tip top shape and you wont have issues.
everything must be as new before you undertake one of these conversions otherwise your vehicles troubles will be magnified, not because of the manual swap but because you are likely driving it harder than you did with the auto box.
Old Dec 12, 2024 | 03:10 AM
Mguar's Avatar
If you’d like to just try a feeling of controlling your shifts without the massive expense of going to a manual conversion.
For a modest fee just about any transmission shop can convert it from automatically shifting to one you have to select the next gear. ( no a clutch isn’t involved ) you just move the lever when you want to shift. Don’t be fooled, it’s still a 3 speed but a 3 speed with a torque converter.( the GM Turbo 400 only has a 2% slippage so it’s pretty crisp.
The 5 speed conversion gives you a lower 1st. Gear to help with the starts and an overdrive ( or 2) to slow the engine down while cruising. Probably gets better gas mileage.
Jegs, Summit racing, Speedway all sell the kit.
I don’t buy the kit because I just drop the valve body and do it in the bench. Go to U TUBE and enter manual conversion of a GM TURBO 400. There are several sites that show you how easy it is
A phone call to your local transmission shop will tell you if you need to buy the kit for them. And what they charge.
No, they don’t need to pull the transmission, just drop the pan, remove the valve body, and pull the modulator.
If they are asking more than $200 call someone else. Yes it’s reversible. Plus you’ll get a fluid change out of it which you’re supposed to do every 65,000 miles anyway. Oops, I probably should have aded the cost of several quarts of transmission fluid.
Old Dec 12, 2024 | 03:36 AM
Mguar's Avatar
Here. In AMERICA you can buy Wilwood calipers and rotors. They sell everything from a slight upgrade to NASCAR Road Racing stuff YES it can be a simple bolt on TO A STATE OF THE ART RACING BRAKING SYSTEM.
With upgrades to the suspension you trade off a civilized ride for the rough, jarring race car ride. But you are still in a 4600 pound car.
To get it down to race weight everything needs to go. And below about 3500 pounds it gets damn crude. With a lot of metal replaced with carbon fiber and no HVAC at all
The potential power increase of a modern car engine is there. Properly done it will start, idle, and run smoothly.
The cost though is a function of time more than expensive parts. It’s done with a lap top and sorting through the various tables
MEGASQUIRT is a self learning system and will start and run as soon as everything is properly hooked up. ( easier than it sounds) getting maximum power is very straight forward. The hard part is all the transition stuff. I’ve never worked with A/C so I can’t even comment about those issues.
Old Dec 12, 2024 | 08:00 AM
Doug's Avatar
And "enjoying" is really what it's all about.
It's a fair bet that anyone doing a manual trans conversion is interested in a higher performance driving experience....but that doesn't necessarily mean turning an XJS into a track car or driving at "9/10ths" at all times.
Whether manual or automatic an old XJS will benefit from suspension overhaul, brake system overhaul, etc.
These cars respond very well to minor upgrades which, IMO, would satisfy most owners. But, if you demand ever-increasingly more performance from the car then the weak areas of the design will become more apparent.
Old Dec 12, 2024 | 09:01 AM
icsamerica's Avatar
Where exactly is the "bolt on" Wilwood caliper and rotors you are refering too? You might be thinking of this setup I did years ago while that was full custom Wilwood machined hats and spindles with ABS. https://www.jaguarforums.com/forum/x...e-works-84536/
Wilwood may have a caliper that kinda' fits but it wont be any batter then stock in anything other than appearance.
Top tip... if you want these cars to stop the low hanging fruit is in the rear setup. Jag setup the rear to basically be along for the ride so inexperienced drivers would be less apt to spin the car with a panic stab at the brake pedal. In modern cars setup for improved braking, ABS take care of that but Jag didn't up the rear brake bias all that much as they could have with the addition of ABS.
Old Dec 12, 2024 | 11:38 PM
Jagboi64's Avatar
Top tip... if you want these cars to stop the low hanging fruit is in the rear setup. .
Could you elaborate on what you might do? Is it simply adjusting the brake balance, or changing calipers in the rear?
I'm thinking of this for my Daimler DS420, which needs all the brake it can get as it weighs an extra 2000 lbs over an XJ. Unfortunately I can't use the outboard brakes of the later cars, due to the semi fender skirt on the body. Anything bigger than the inboard hub carrier and I don't have enough clearance to install or remove the wheel. As it is now, on full droop I only have about 1/4" clearance between the tire and the fender to change a wheel.
Old Dec 13, 2024 | 06:16 AM
Mguar's Avatar
The issue is ease of working on the brakes and brakes fading under extreme usage. Simply not worth changing to outboard brakes for making rear brake work easier in 5-10 years in the future.
There are remote bleeder kits available for the every 2 years brake fluid drain. Moss motors sells one.
The stock front brakes are fine for normal driving. Don’t go swapping in different calipers for some imagined superior braking. Unless you frequently race the car or tow heavy loads in mountains regularly.
Old Dec 13, 2024 | 10:37 AM
icsamerica's Avatar
If you can't go outboard then not much you can do other than brake pads with a higher co-efficient of friction. Try the EBC reds or blues all around. Also make sure the diff seals are not leaking oil onto the rotors and contaminating the pads, this is common. The cars with rear inboard brakes have low levels of rear bias designed in by the use of a small caliper pistons and really small pad size. There was a smaller outboard brake setup with a thin solid rotor on the inline 6 XJ in 88 and 89, You might be able to squeeze the wheel around that setup. I could easily see how the later outboard setup with the large vented rotors could be problematic on a DS420.
Old Dec 13, 2024 | 10:47 AM
ptjs1's Avatar
If you're looking to change to outboard rear brakes, remember that the early outboard 4.0 cars have solid, not vented, rear discs. They only changed to vented ones in October 1994 at VIN 198335.
Paul
