Modern Throttle Position Sensor Upgrade Write-up (much cheaper than OEM!)
Although you can thread into this stuff I prefer to use captives. You can get special inserts, some melt in, some screw in, some behave like rivnuts but I've no experience of SLA printing. Worst case you can use anti vibration washers - it is going to expand and contract in this area, brass set screws are useful in such locations..
Personally I would remove the adjustment from the TPS itself and do it on the main body that you can be a little less delicate with the tightening.
On mine I used extremely coarse threaded screws, similar to what you'd use in wood (and I tightened the **** out of them).. if you're really confident in the adjustment you could always just throw some epoxy on there and never worry about it again
You should be able to take 10 thou or so off the top of the adapter to smooth it out without causing any issues, even just sand paper would likely give you a better mating surface for the sensor.
out of curiosity Garet what kind of resin is that? Looks like it held up to the heat very well
Does anyone have a new link to buy the sensor? The eBay link no longer shows the screws and plate you would need for this to work. There are several Amazon items that appear to the same thing, but the cheap ones say 360 degree, and the expensive ones say 0-90, 0-180, 0-360.
Might be worth checking sites like aliexpress or other chinese wholesalers for it as well
I will eventually put together a complete kit to sell along with a transmission swap kit and a couple other little things I'm working on, around 6-12 months from being ready to do that
This is great news for V12 owners!
Millarjs
Oct 10, 2023 12:10 PM
