Mystery connector solved
Old Jul 14, 2016 | 10:56 PM
Doug's Avatar
Default Mystery connector solved
I can't find the original posting but I'm 99% somebody was asking about a mystery connector. This is a two-pin connector just aft of the throttle turntable and above the big balance tube. Brown/slate and pink/white wires.
I think I figured it out. It goes to the Supplementary Air Valve (backside of RH air filter housing) and the Solenoid Vacuum Valve (blue widget at rear of RH inlet manifold)
I discovered this as I near completion of my '88 V12 project
Hope this helps
On a totally unrelated note I included a pic of some sorta neat wire ties I've been using. They're aluminum, easily adjustable, and reusable. I thought they look a bit more upscale than some of the other choices. They were leftovers from a Corvette project
http://www.parts123.com/corvettecent...50e&ukey=45822
Attached Thumbnails Mystery connector solved-xjs-mystery-wire.jpg   Mystery connector solved-solenoid-vac-valve.jpg   Mystery connector solved-corvette-wire-tie.jpg
Old Jul 15, 2016 | 03:45 PM
williewilkens's Avatar
Thanks, Doug! I don't know if I have THIS random connection hanging around...but I know there are plenty! I like the look of those wire ties, too. Very clean...
razorboy
May 5, 2016 09:57 PM
scottpeterd
Apr 3, 2016 09:07 AM
kr98664
Mar 26, 2016 06:25 PM
dubydogg
Mar 30, 2007 01:10 AM
andersen06
Mar 8, 2007 11:10 PM
