Need help to resolve best methods
Old Feb 7, 2020 | 02:23 PM
BlueXJS's Avatar
Default Need help to resolve best methods
1989 XJS convertible.
Has had little use recently hence ceased waterpump.
Question:
Can the waterpump be changed without removing the radiator?
__________________
1989 XJS V12 (added by GGG)
Old Feb 7, 2020 | 02:38 PM
Welcome to the forums BlueXJS,
I've moved this duplicate version of your Intro to XJS forum for advice from members with the same model.
Old Feb 7, 2020 | 03:37 PM
Steve M's Avatar
How do you know that the water pump has ceased?
Old Feb 7, 2020 | 05:41 PM
JayJagJay's Avatar
Question:
__________________
Hmm... To do it carefully, I wouldn't wanna... Once at it, removal of the rad in this job is actually not tough... If she sat long enough to have concerns about the pump you might wanna spin the rad around, turn it up and down,,, and give it a good old fashioned flush and fin cleaning anyways.
I would remove it and save some knuckle skin.
Old Feb 7, 2020 | 09:14 PM
I agree.
If its sat long enough, probably with WATER in it, then the WHOLE cooling system needs a refresh.
SORRY, there are NO shortcuts with a V12.
Read the sticky at the top for an insight into the minefield if its NOT done 100%.
However, YES the pump can be removed with the rad insitu, GREAT care is needed, and the extra time taken to provide that care, would have the radiator out and in 3 times, makes no sense, even to me.
Old Feb 7, 2020 | 10:59 PM
Doug's Avatar
I'd pull the radiator...and while it's out send it to a radiator shop for pressure testing and professional cleaning.
At this point you're half way thru a full cooling overhaul so, unless your 100% sure such work has been recently done, now's the time. Hoses, belts, fan clutch, thermostats (correct thermostats, that is!), cleaning the small vapor pipes, flush, and proper bleeding of the system. Do it all, do it right, do it once.
(I suspect this ^^^^ is a repeat of what's recommended in the article Grant mentioned)
Old Feb 8, 2020 | 06:48 AM
JayJagJay's Avatar
BIG +1 on the correct thermostats.... Wiggle pins UP....
One of the most common challenges for these cars is the coolant system... One of the first jobs I had to do,,, and there was/IS a string was the water pump (thanks Grant) and in doing this (x3 sad to say) I learned a great deal about the monster... X3 had to do with getting it so it wasn't dribbling. I wasnt careful ENOUGH in setting gasket and bolt in. Fiddly fiddly machines these are,,, and fine lines around the pump fitting...
Old Feb 9, 2020 | 04:45 AM
BlueXJS's Avatar
there is a high loud squeek from that area when its running.
Also if I turn the waterpump for a few turns before starting then its fine until the next time I start it.
Old Feb 9, 2020 | 04:59 AM
orangeblossom's Avatar
Hi Blue XJS
Maybe you have a loose Drive Belt or maybe it could be the fan Clutch?
The Drive Belt on my Car would always start squealing until it got warmed up but now its been adjusted doesn't do that anymore, though if you're still mulling it over now would be a very good time to make sure all the drive belt adjusters are free and the threads of these are coated with Copper Grease
As when I had a Fan Belt snap, that took out the CPS I was really, really glad that I'd done this
vinny jones
Oct 5, 2015 07:20 AM
dylanlyn
May 4, 2014 08:30 PM
gthawk1
Nov 25, 2013 11:44 AM
bocagq45
Sep 17, 2013 07:54 AM
