New black mechanical fan
Old Nov 21, 2016 | 10:45 AM
Daim's Avatar
Default New black mechanical fan
Hi there,
After checking my fan blades, I want the new fan... Mine has 4 deep cracks around the central mounting section.
I've read here somewhere, and can't find it anymore (would be nice if the search worked better), that the new black fan blade does not fit the normal viscous clutch. My clutch still works well so I only want to replace the blades... (EBC4553)
Does anyone here have the exact measurements or the bore and screw pattern of the mounting surface? Metric please
Damien
Old Nov 21, 2016 | 12:52 PM
Jagboi64's Avatar
I just happen to have a spare black fan. Center bore is 2.60" /66mm, bolt holes center to center seem to be 2.30"/ 58.5mm. There is a ring of perforations at the edge of the center steel plate that the clutch bolts to, the clear diameter inside those holes is ~5"/130mm.
For working on these cars you know you really need a set of inch sized tools!
Old Nov 21, 2016 | 01:08 PM
Daim's Avatar
I have a set of imperial tools, thats not the worry. I needed the measurements to determine if I need another torquatrol unit or if I have the right one already
Cheers!
Old Nov 21, 2016 | 01:14 PM
Jagboi64's Avatar
I swapped a yellow fan for a black one on my Daimler DS420 and it bolted right up to the old clutch unit, so it should be a direct fit for you.
The clutch has to come off anyway, so it doesn't matter. If I remember correctly, the fan and clutch has to be removed as a unit from the car; and each nut that holds the clutch to the car needs to come off a bit at a time. There isn't enough space to remove it completely and move to the next nut. That's certainly true when reinstalling it.
Old Nov 21, 2016 | 01:15 PM
Daim's Avatar
All long time removed... Without removing it, you can't get the blades off...
Old Nov 22, 2016 | 04:13 AM
user 652867429824's Avatar
I swapped out my old yellow fan for the new black and had no problem
Old Nov 22, 2016 | 04:51 AM
leo_denmark's Avatar
Same story here, black EBC4553 fitted straight on my '89 HE engine.
I liked the look of the white fan though, but I also like to keep my bonnet free of dents from an exploding fan...
Old Nov 22, 2016 | 05:19 AM
Daim's Avatar
I remember reading it here... But if it all works without any hassle then all is fine...
Old Nov 22, 2016 | 05:42 AM
newbound7's Avatar
[url]https://www.jaguarforums.com/forum/xjs-x27-32/black-fan-doesnt-fit-wrong-clutch-167255/
Was this what you read before ?
Old Nov 22, 2016 | 09:27 AM
jal1234's Avatar
The black fan won't fit some aftermarket clutch replacements that fit the yellow fan. Complete info is the Kirby Palm's "The Book".
