new jag owner - joke is on me? "rookie prank"?
Old Feb 16, 2010 | 08:20 AM
rama1200's Avatar
Default new jag owner - joke is on me? "rookie prank"?
well... I decided to drive "classy-cat" today... went o drop my son to school, etc. etc.... I see that I need gas... I stopped at the gas station... to find that I cannot open the gas tank cap... is locked?
how do you unlock it? I don't see a latch/button to pull/press on the inside to open it.... I know it has something to with the car-locking mechanism...
I made it to work... but will need gas to go back some...
Any ideas?
Old Feb 16, 2010 | 08:57 AM
Brutal's Avatar
Yr and model my crystal ***** are all broken
Old Feb 16, 2010 | 09:03 AM
rama1200's Avatar
sorry... I thought I had it in my signature.... I need to review that...
1994 xjs 4.0 6I
Old Feb 16, 2010 | 09:07 AM
Brutal's Avatar
Should have a solenoid activated pin lock. Make sure your doors are unlocked first. Then if so, pull back the trunk liner by the gas door and youll see the solenoid on the filler neck, pull back the pin to unlock. If the solenoid has failed you can replace or unplug it and leave it unlocked
Old Feb 16, 2010 | 09:12 AM
rama1200's Avatar
Thanks, Brutal...
other than unplugging it, is there a "proper" way to open it?
I remember that the first time that I put gas in it, I just pulled it open... then this time (2nd time)... I got the big surprise...
Thanks, again
I'm on my way to the parking lot right now....
Old Feb 16, 2010 | 01:58 PM
rama1200's Avatar
finally i got to open the trunk... removed some "control panel" and got access to the pin... pushed it back... I could not unplud the actuator... it was too hard and did not want to force it....
I noticed that after I put gas, came back to office, etc... locked the doors - as usual by hand with the key as I don't have a remote - and the pin moved back to the locked position... I unlocked the doors and the pin unlocked... right now is back to the locked position... will wait and see at home what is the trick...
these cars really need to have an inner truck and gas cap release.... or is mine missing it?
Old Feb 16, 2010 | 02:01 PM
Brutal's Avatar
Try lubing the pin assembly, maybe just dry and old....the pin not you
Old Feb 16, 2010 | 06:11 PM
rama1200's Avatar
LOL.... I'm glad you clarified.... at least you didn't say "old piece of junk!"
Old Feb 17, 2010 | 08:04 PM
Aromas Jim's Avatar
Rama1200. I have the same year and model car. I don't have a remote either but read in owner's manual that the doors can be locked by holding the inside door handle out and moving the locking level (vertical level in front of the handle) back towards the handle. You should hear both doors lock as well as the boot and gas door. This saves wear on your key, I wore one out already. When you unlock the door with the key, all four items should unlock together.
Old Feb 17, 2010 | 10:05 PM
Brutal's Avatar
OLD, does not meen junk! I work on new ones that are junk, just depends on the care given in my opinion
Old Feb 18, 2010 | 03:07 AM
jetlag700's Avatar
Any ideas?
I just use my key to unlock the door to the gas cap~!~!, Alright, I won't make fun of a rookie~!~! ha
I dunno, my car is 22 years old without all the new fangled gadgets and lockdowns~!~! What model and year is it? That would really help someone to help you, otherwise you'll be hitchhiking~!~! Donna
Old Feb 18, 2010 | 10:44 AM
rama1200's Avatar
Thanks, Jim... that is kinda what I was looking for.... is there something that we can do with the key to lock/unlock the gas?
Old Feb 18, 2010 | 10:46 AM
rama1200's Avatar
she is a 94.... I'd figured that it has so many electric components that for sure it has to have something for the gas cap... I still don't see a lever inside (anywhere) to open truck or gas....
Old Feb 18, 2010 | 10:48 AM
rama1200's Avatar
I know...
I was talking about me ;-)
Thanks all for your help
Old Feb 20, 2010 | 08:21 PM
Aromas Jim's Avatar
OK, I've checked my car's owner's manual and it says... "Fuel filler flap emergency manual release (Coupe) is a GREEN plastic strap and pull inside the luggage compartment on the left-hand side behind the lamp". The photo shown in the book does not show the remote CD changer, which is also located in this area. If you have one in your car, then you'll probably have to remove the panel surrounding the CD changer to find the pull.
Forcedair1
Sep 8, 2025 01:57 PM
allenman85
May 10, 2021 03:11 PM
FeralJag
Jan 11, 2016 05:07 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
Sep 3, 2015 12:21 PM
