new rad different fittings what to do
Old May 4, 2012 | 08:09 PM
Qgregg's Avatar
Default new rad different fittings what to do
identicle rad came in but with diff fittings, mine had screw on type pressure looking fittings for trans fluid, this one has low pressure slip on tubes coming out. what to do??? 2 of them on the passenger side u.s. one under rad hose and one on bottom above other rad hose....
Old May 4, 2012 | 09:11 PM
M90power's Avatar
i would get an aftermarket trans cooler, and take that BS up with the seller. those transmissions put out well over 100 psi on the high side of the pump. i dont know what the output rad line pressure should be.
Old May 5, 2012 | 01:31 AM
Greg in France's Avatar
The rad fittings for the oil cooler changed about with the 1988 models, from push-on plus worm drive clip to screw-on fittings for the trans lines. The push on work fine, by the way. Either take the rad back and ask for the later model with screw on fittings, or bodge up the hose ends as required.
Good advice about an extra trans cooler though!
Greg
Old May 5, 2012 | 05:54 AM
M90power's Avatar
so apparently the output line pressure isnt that high.
trans cooler should be a requirement anyways. ive seen too many good jags die because of bad radiators leaking coolant into the trans and trans fluid into the coolant.
Old May 5, 2012 | 06:36 AM
warrjon's Avatar
The later Rads had more fins and cool better, I found this out when I had mine re-cored the guy told me there were 2 different cores
Old May 5, 2012 | 06:54 AM
Qgregg's Avatar
Thanks guys, ill see if my radiator guy can change the fittings if not i'll cut the hose ends to slip on and clamp.
Old May 5, 2012 | 09:58 AM
Greg Edge's Avatar
There is line pressure at those fitting. No problem with hose clamps. We use them on the fuel system and if dead headed the pressure goes quite high with no problems. Some manufacturers use hose clamps on A/C lines.
Early cars had a hose with clamp connection, later cars have flare fittings.
aholbro1
Dec 29, 2024 06:46 PM
xjrjag
Oct 24, 2024 03:09 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
mhamilton
Sep 12, 2015 03:21 PM
