New springs and shocks
Old Oct 15, 2015 | 07:32 PM
Dave1109971's Avatar
Default New springs and shocks
Guys as I have the IRS out and noticed a damaged KYB shock I was going to replace all 4 with Boge (the fronts are boge) should I also replce the springs at the same time? If so I'd look at King Springs I notice that some people on here have them on their cars are those people happy with them?
Old Oct 15, 2015 | 08:27 PM
Norfolk Enchants's Avatar
I have just bought four new Boge shocks for the rear of my XJS. I haven't fitted them yet but did not get the springs. I wanted to do the springs but could not really find a good recommendation for a like OEM ride height and spring rate - I was fearful that the beutifull ride height would end up being raised. If you get a good bit of advice here I will likely do my springs too
I noticed that my car would sometimes lean slightly to the left at the rear, so it could be the dampers, but likely I do too need the springs.
Old Oct 16, 2015 | 06:33 AM
ptjs1's Avatar
Dave,
There's lots of threads on here about replacing springs and shocks. Here's teh most recent one:
https://www.jaguarforums.com/forum/x...shocks-151020/
Paul
Old Oct 16, 2015 | 07:09 AM
Steve M's Avatar
I fitted Aston DB7 springs, radius arm bushes and cage mounts; it gives a tighter setup at the back but the ride height is the same.
Old Oct 16, 2015 | 09:48 PM
Very interesting. Sounds like a good set-up for a driving enthusiast, Steve. Great to hear that you kept the orig ride height with this set-up - these cars sit so nice!
Old Oct 18, 2015 | 06:17 PM
warrjon's Avatar
Check out Selby, I used their HD standard height in the rear of mine and are happy with the result, slightly cheaper than the King. I also used Bilstein shocks all round. Very happy with the result, not noisy or harsh but tightened up the handling significantly.
Old Oct 18, 2015 | 08:09 PM
jal1234's Avatar
Do you have part numbers for the parts you used?
Old Oct 19, 2015 | 02:13 AM
Righto thanks for the info guys. I've gone with a set of Boge from Jagdaim and a set of King Springs (std Height) I would have got bilsteins only that the Boge are at a price I couldn't say no to.
Old Oct 19, 2015 | 03:05 AM
Steve M's Avatar
The only number that I could see is from a photo and I'm not sure if it is for the radius arm bushes or the cage mounts; either way it is DOC613950.
jagincumbria
Oct 22, 2015 11:19 PM
AntXJ
Oct 20, 2015 01:39 PM
RFXJ12
Oct 18, 2015 07:32 PM
xjrjag
Oct 13, 2015 02:16 PM
EZDriver
Oct 13, 2015 12:30 AM
