No interior lights
Old Jun 14, 2022 | 12:50 PM
jomo's Avatar
Default No interior lights
Hi,
I am in the process of moving and packed all my Jaguar books.
My interior lights are not working. I checked all the fuses in two locations---under the hood and under the location where the glove box should be.
Are there other fuse boxes in this car? If yes, then where? Any other things I should check for to get my lights working again?
Thank you,
Jomo
Old Jun 14, 2022 | 01:53 PM
brinny's Avatar
Earths
Old Jun 14, 2022 | 02:33 PM
jomo's Avatar
Where would I even start to find the grounds for the interior light? I will check to see if one of the lights have a ground, if not I guess I can supply one.
Did I locate all the fuse boxes?
Old Jun 14, 2022 | 02:37 PM
brinny's Avatar
Probably best to wait for Greg in the morning he will know. Same goes for your other post.👍
Old Jun 14, 2022 | 11:44 PM
imitch1303's Avatar
Don't want to be the one that states the obvious, but have you checked that the light comes on when you toggle it to the rear position (always ON). I had the same issue once, so I pulled and cleaned the door switches, only to find out I had knocked the light into the centre position (always OFF).
Old Jun 19, 2022 | 07:19 PM
Time-Pilot's Avatar
Drivers side kick panel, behind there is a black wire with a red stripe, that's the power for the interior lights. I only know this because someone hacked through mine and I found it working on another project. Not saying it's not something else, but that's the power feed.
Old Jun 19, 2022 | 07:29 PM
jomo's Avatar
This wire is always hot?
Old Jun 19, 2022 | 09:47 PM
Time-Pilot's Avatar
I'm not sure, if no one knows I check that wire for you tomorrow.
Old Jun 20, 2022 | 12:39 AM
Greg in France's Avatar
Yes, always hot. I have a feeling it is actually purple with a stripe. I would start by making sure you have power at the lights. The under-dash units just prise out, as does the central one in the roof.
Do any of them come on with the dash board switches? Does the central roof light come on when rotated to the "on" position?
Also, even if not coming on, open a door and see if any of them have power and report back.
Slochap
Nov 18, 2022 07:04 PM
Fairfalcon
Nov 1, 2017 04:17 PM
whitney12
Nov 24, 2014 07:03 PM
swoop22
Nov 1, 2011 06:48 PM
nsl1
Jun 30, 2011 12:29 PM
