Noob, any advise?
Old Feb 21, 2009 | 07:05 PM
Doug's Avatar
The Jag V12 engine will last darn near forever...so long as it runs cool. I'll wager that 99% of dead Jag V12s were overheated. So, make sure the cooling system is 100% up-to-snuff. Volumes could be written on the subject but, in a nutshell, if the temp gauge goes past the middle of the "N" you have some work ahead of you.
About 1/2 way thru the '89 model year Jaguar switched from Lucas to Marelli ignition (VIN break apprx 157xxx). The Marelli ignition is responsible for lots of burned up Jags so, if this car has it, plan on new secondary ignition parts ($$$$) just on general principle....unless service records show recent work in that area. Some owners convert to the Lucas ignition which is more reliable. Marelli ignition has two coil wires going into the distributor cap...easy to spot.
Inoperative A/C can be simple....or it can be a huge problem. If the climate control changes modes on command you'll know that the system is fundamentally operational, at least.
The rear brakes are inboard mounted. Changing pads is a breeze but replacing calipers, rotors, and axle seals is labor intensive. Proof of recent work here would be a real "plus".
Check for fuel odor in the trunk. If it smells, brace yourself for some work which may or may not be sucessful.
Plan on replacing the fuel injection hoses if the existing ones are more than 5 years old.
Despite what I've just written these are fabulous cars....about the same performance as the earliest 928s and terrific on the highway. But, they have lots of quirks and many are not well cared for. The usual scenario is to spend a few weekends and a chunk of money catching up on all the repairs and services that the previous owner shrugged off....but it sounds like you're used to that. Once everything is sorted they're a dream
Old Feb 22, 2009 | 07:21 AM
Keven's Avatar
TTT, same situation except mine is missing a conv top and title
Old Mar 5, 2009 | 03:01 PM
speeedracer's Avatar
Check the body lines on the pass side carefully. The door not opening sounds like accident damage. Check all the rust spots, I've seen some great looking cars in pics and then when you get next to them you see the bubbles :-(
Old Mar 6, 2009 | 06:28 AM
mbannister's Avatar
Front sub-frame may be rotten.
Oh yes, love 'em in white. I had a white facelift once with red leather and interior.
JaguarLover101
48
Jun 12, 2023 10:28 AM
jazzman20014
Oct 26, 2015 04:15 PM
Inspector
Oct 17, 2015 12:51 PM
Collector1
Sep 26, 2015 05:28 PM
sonofdave1980
Sep 14, 2015 07:45 PM
