Noobie got a dead XJS :-(
Old Mar 24, 2009 | 10:15 AM
Geofux's Avatar
I would personally check all the relays and fuses to make sure they are good.
I'm not sure if the immobiliser will stop the fuel pump from working just as well as stopping the starter from doing it's thing. In my XJ6 I have neutral start switch problems... I'm wondering if it could also be another problem with your car? Have you shifted the car out of park and back to park then try starting it? If that doesn't work on my car I can also hold the key forward and within 5-10 seconds it will start to crank over (probably doesn't have to do with the neutral start switch - but I'm not sure).
Hopefully this helps.
My uncle has a '96 and it is in near mint condition. It's a very nice car to drive and definitely gets a lot of looks.
http://geof.lolshame.com/cars/Jaguar/DSC03482.jpg
Old Mar 24, 2009 | 12:53 PM
ken@britishparts.com's Avatar
Need lots more info here. Just to start simple, what did you do to the battery if the car has sat for 3 years?
Rivguy
Nov 13, 2022 02:55 AM
ferraripete
Sep 12, 2016 09:02 AM
CXJ
Nov 28, 2015 11:41 PM
mhamilton
Oct 8, 2015 02:17 AM
Tim Goz
Sep 17, 2015 09:11 AM
