Not for the faint of heart!
Old Mar 21, 2013 | 09:37 AM
Oddrods's Avatar
Default Not for the faint of heart!
I don't know if this has been posted before but how aboout some pictures of some of the mods you have done to your cars? I am still finishing up a couple of interior mods that should be done by the end of the week. When they are done I'll post pictures for you all to hopefully enjoy or not. Either way I don't offend easily so comments are welcome.
Old Mar 21, 2013 | 09:41 AM
Oddrods's Avatar
Hopefully I just posted a picture! In this shot you will see that my trip computer is gone and replaced by a narrow band air/fuel gauge. In addition my wood was in horrible shape so I sanded it smooth and re-veneered it with 3M di-noc vinyl clear coated with 3 coats of clear. Most of the wood has been done this way and it looks great! Very easy to do as well. More pictures to follow.....
Old Mar 21, 2013 | 12:24 PM
ronbros's Avatar
Default just a couple mods ,78 XJS rodster
i'll join the party.
some pix of couple mods, i love mods , anyone can just buy a standard car, but mods are kool!
all mods done by me,everything including body,paint,engine trans,suspensin, interior, but i bought the seats ,and dash veneers. spun Burlwood,still perfect.
notice gage left of consul A/F ratio.
all done 18yrs ago, yikes has it been that long,actually had the car 20yrs this yr.
no door handles,(key fob). wide rear fenders.
Attached Thumbnails Not for the faint of heart!-jag-rodstr-016.jpg   Not for the faint of heart!-jag-strips-10-22-2012-001.jpg   Not for the faint of heart!-jag-strips-10-22-2012-004.jpg   Not for the faint of heart!-jag-strips-10-22-2012-006.jpg   Not for the faint of heart!-jag-strut-brace-mom-ridin-shot-gun-v12-exhuast-mani-001.jpg
Not for the faint of heart!-jag-strut-brace-mom-ridin-shot-gun-v12-exhuast-mani-008.jpg   Not for the faint of heart!-center-consol-j-bond-system-003.jpg   Not for the faint of heart!-center-consol-j-bond-system-001.jpg   Not for the faint of heart!-jaguar-engine-build-process-001.jpg   Not for the faint of heart!-jaguar-engine-build-process.jpg
Old Mar 21, 2013 | 12:25 PM
Sarc's Avatar
@Rob
I like it. Your wood looks pretty good too. Could you maybe paint the 2 rivets (?) on either side of the gauge also flat black ? They kind of distract your eyes a bit.
Unfortunately because I have a dodgy fuel gauge I rely on my trip computer to prevent me from running out of gas. I have fitted aftermarket gauges (fuel pressure and oil temp) to my car and I was thinking about putting them where the trip computer was....... might try a change one day.
I see you have the updated 2 way center vent mod done....... that was one of the best/easiest things I've done to the car
@Ronbros
I love the James bond console.....
Any info on the cross brace that goes across the engine... home made ? Is there enough clearance to the hood ? Do you run a hoodliner ?
Also, any info on the headlights ? It looks like you have single units on the outside, and "something" LEDs ? on the inside ? Weirdly enough I have been looking for small compact bi-xenons to try out something similar.....
Old Mar 21, 2013 | 12:30 PM
ronbros's Avatar
almost forgot,its a lightweight, at an actual 3360lbs,1/2 tank fuel, no driver!
add this pic
Old Mar 21, 2013 | 12:36 PM
ronbros's Avatar
Faint of heart??, my wife would if she knew how much i spent!
Old Mar 21, 2013 | 12:38 PM
Oddrods's Avatar
Actually I am not familiar with the vent mod. Is this something that was done by the previous owner?
Old Mar 21, 2013 | 12:46 PM
Sarc's Avatar
Yes. The standard center vent for your car was a 3 way vent. Only the small left hand side and right hand side parts could move. probably 2/3 of the air went out of the middle of this vent and straight onto the back window, or the rear passengers that can't actually fit in an XJS. As you will know, you only get air out of the center vent when you have the A/C on, so this made the A/C "feel" less effective. Having ran the car with A/C both ways I think it's partly psychological because I could get the small cabin freezing without the upgraded center vent, but somehow having cool air blowing on your face seems to make you think the car is colder.
The 94 and up cars came with the 2 piece center vent you have, so now you can redirect all of the cool air and freeze the driver and passenger if required. It's an easy 15 minute job to swap them over..... just pull the center wood trim part off then I think the vent pulls out..... or its 2 screws..... easy anyway
Old Mar 21, 2013 | 12:55 PM
Oddrods's Avatar
Unfortunately my HVAC is all screwed up. I get 98% of my air out the defroster ducts. My heat is only intermitant and the a/c sorta blows a little colder than ambient. My fan only works on "high" and when it starts up it screetches something fierce! There is also a sound like a vacuum leak from under the dash. Other than that it's great!
Old Mar 21, 2013 | 01:02 PM
Sarc's Avatar
Minor niggles :-) At least when you do get it working you have the improved center vent :-)
Old Mar 21, 2013 | 09:20 PM
JameyXJ6's Avatar
I will take pic's as soon as enough snow melts that I can get TO the car! It almost had a major body modification 2 days ago when the last snowstorm dropped heavy, wet snow and collapsed my carport. It missed my car by just inches!
Old Mar 22, 2013 | 12:45 PM
DrScientist's Avatar
@Ronbros...
why not little stickers or plates reading "ejector seat" "oil slick" "missiles" for the center console toggles?
also, whats the white cord to the gear shifter? is that an engine fire extinguishing system?
Old Mar 22, 2013 | 01:07 PM
Oddrods's Avatar
Today's project. My shifter whiskers are always shedding and look a little cheap to me even when they are good so I replaced them with a rubber guide. I think it's a little cleaner looking. The shift knob is an aftermarket one for a manual transmission. In order to make it fit without modifying the stalk I milled out a slot in the hole. I then drilled and tapped 2 set screws higher up on the ball. This locks it in place as well as keeps it located fore and aft. I will then use shrink tubing at the base of the ball to blend it in with the chrome stalk. I also had to add the shift pattern and "wood grained" the aluminum ring to match the rest of the wood.I will snap some pics when they are installed. BTW: I also am aware my shifter cover is in poor shape. I am one of the lucky one facing possible layoffs so everything I do now needs to be on a budget. The plus side of working with messed up parts is I can experiment on them and perfect the techniques and try different looks without fear!
Old Mar 22, 2013 | 02:16 PM
Oddrods's Avatar
And now it is installed
This is my 12v/USB solution. I got tired of my Garmin adaptor falling out of the stock cigar lighter. I have another face plate with the wood grain in the correct orientation drying now.
Attached Thumbnails Not for the faint of heart!-20130322_140645.jpg   Not for the faint of heart!-20130322_140726.jpg
Old Mar 23, 2013 | 01:00 AM
inertian's Avatar
Oddrods - some very elegant solutions to common problems. I particularly like the rubber guide replacing the shifter whiskers (is that what those brushes are really called?!). Any details on what you used, how you cut and fit them, etc. appreciated. Mine are pretty well worn and need to go.
Power-wise, I've been running a Black and Decker 100-watt power inverter ($8 at HomeDepot), it has a USB port and a 115-volt AC outlet. It doesn't sit in the shallow lighter receptacle as securely as I'd like, but I'll either install a deeper one or integrate something like you did.
Old Mar 23, 2013 | 06:30 AM
Typhoon's Avatar
Love the shifter gasket Oddrods.
I'll be doing plenty of subtle mods to my car, but a lot of them are some way off at this stage....
Terry007
Mar 5, 2019 06:42 AM
99Gsp
Sep 26, 2015 04:10 PM
axr383
Sep 12, 2015 01:32 PM
Broken_Spanners
Sep 6, 2015 11:34 AM
