Oil pressure.
Old Aug 10, 2015 | 09:29 PM
nick.R's Avatar
Question Oil pressure.
Hi all.
Just bought 95 xjs from FL with 57K on the clock. While driving back to PA I saw that when at idle the gauge would show about 10 lbs. But when driving the gauge shows around 40 lbs. Is it normal to show that low of a pressure at 750revs?
thanks
Nick
Old Aug 10, 2015 | 09:32 PM
Doug's Avatar
No worries IMHO. Not low enough to cause a problem.
Rule of thumb is 10 psi for every 1000 rpm when warm
Old Aug 11, 2015 | 09:34 AM
RagJag's Avatar
My '96 4.0 does that too. The 750 idle speed is supposed to be 600 though, if this a 4.0.
Cheers, RagJag
Old Aug 11, 2015 | 04:23 PM
ptjs1's Avatar
That's not 40psi its showing, its 4 bar pressure (assuming US gauges are the same as UK). 4 bar pressure is 58psi. If so, that's fine. XJS 4 litre oil pressure is 2.75 bar at 2000rpm.
Paul
kthrash
Feb 25, 2019 10:20 AM
JCam
Oct 23, 2016 08:27 PM
caldoofy
Sep 28, 2015 08:43 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
