Over Heat
Old Jul 13, 2022 | 03:03 AM
  #41
ptjs1's Avatar
Originally Posted by Captain Bob 369
Thanks for the info, normal running it never goes past the middle. When I spin the fan by hand it maybe makes one revolution which should indicate it’s operating as it supposed to. An additional fan placed on front is the radiator should fix it for parades.
Captain Bob 369,
Don't install another fan. 4 litre XJS don't overheat even in parades. There is a problem somewhere, either in the rad, as mentioned, or in the fan. You just need to work out where is the problem. Have you looked at the cooling fins and the space in front of the rad, as has been suggested? Pull the rad out, examine it carefully, fully flush it, and if you're fan is working correctly, you'll be fine.
Paul
Old Jul 13, 2022 | 07:32 AM
  #42
Vee's Avatar
Vee
If you’re getting a full rotation, replace the clutch. Even if it’s close to a full rotation.
Old Jul 13, 2022 | 07:43 AM
  #43
Captain Bob 369's Avatar
Default Over Heat
Any suggestions where to purchase?
Old Jul 13, 2022 | 08:31 AM
  #44
Jagboi64's Avatar
SNG Barratt or Rockauto.com are both good.
SNG is a forum sponsor and gives a discount to members.
Biff Baxter
Jul 6, 2017 09:44 AM
workworkwork
Nov 9, 2015 10:48 PM
YycXJS
Jul 29, 2014 10:56 PM
jagtoes
Jul 6, 2014 06:36 PM
jmrjames
Feb 2, 2010 11:22 PM
