Parking brake sticking in '90 convertible?
Old Mar 10, 2016 | 11:55 AM
gkazimir's Avatar
Default Parking brake sticking in '90 convertible?
So....after the winter my girl is starting to get out and see the sights again. But I'm having a bit of an odd issue.
When I go to release the parking brake after taking the top down, I'm not sure if it's releasing or not. The parking light stays on, and it's taking 5 or more attempts at variously engaging and disengaging the hand brake for it to indicate it's indeed off.
Is this a light problem - and if so, how on earth will I tell if it's engaged or not?! - or a cable/brake issue? Thoughts?
Many thanks!
Old Mar 10, 2016 | 01:12 PM
Greg in France's Avatar
Under the black plastic cover covering the handbrake lever fulcrum is a microswitch that does the warning light. remove the cover and adjust the switch's position so it goes off when the HB is released.
Greg
Old Mar 12, 2016 | 09:11 AM
gkazimir's Avatar
THANK YOU! I'll check on that for sure. - Gina
King Charles
Apr 26, 2016 07:40 PM
caldercay
Jan 14, 2016 06:26 PM
Ben7
Mar 7, 2015 12:12 AM
jag79
Sep 22, 2010 01:46 PM
