Parking brake stuck! 94 Jaguar XJS
Old Jul 26, 2014 | 10:34 AM
JagNewbie28's Avatar
Smile Parking brake stuck! 94 Jaguar XJS
I'm a newbie to the forum but I need help getting the parking brake unstuck. The actual lever works fine but it's stuck under the car somehow... My dad just passed the car down to me and I wanna get it fixed before summer ends if possible but no one in our small town of Somerset KY will work on it! Any help is much appreciated!!!
Old Jul 26, 2014 | 10:39 AM
Greg in France's Avatar
Did you know that to release the handbrake, you have to: depress the button; pull the lever up to take the tension off the cable still holding the button depressed; than lower the lever STILL holding in the button until the lever is back to the floor?
Greg
Old Jan 25, 2018 | 01:14 PM
Croods's Avatar
Old question but find it useful after 4 years. Great share Greg
Old Jan 26, 2018 | 07:56 AM
Andreas Schmieg's Avatar
Sounds like my corner repair shop. XK8 timing chain replacement - rejected after 1 hour. V12 tune-up - rejected after 1 hour. Replacing the V12 cooling system - took them one week to even dare to touch the car. And then they did a great job.
Old Jan 26, 2018 | 12:33 PM
macdoesit's Avatar
Banned
Let us know if and how it was fixed.
Old Jan 26, 2018 | 08:29 PM
orangeblossom's Avatar
Hi JagNewbie
It sounds as if the Handbrake Cable has stretched to its fullest extent, which seems to mean that you won't be able to pull
The Handbrake Lever up any higher than it is at the moment
Which you would need to be able to do before you can release it, in the way that 'Greg' described
When the Handbrake Cable starts to stretch to the point at which it its nearing its limit of Travel, that is an indication that the
Handbrake Cable needs adjusting
So that you still have some 'Pull up Travel' (Left in Reserve) which you would need to release it
In the event that this should be the case?
You may need to adjust the Handbrake, which is very easy to do (relatively speaking)
The Adjusting Rod (which is basically just a threaded rod) with a couple of 'lock nuts' is just behind the 'drivers seat' under a
Piece of carpet very close to the sill
The Photos will show you exactly where it is
So when you find it just undo the 'lock nut' and adjust it, so you've got some Tension on the Cable, which 'may' repeat 'may'
Just give you enough upward movement of the Handbrake Lever
To release it, although if not you may have to release it from under the Car
If you can manage to release it one way or another, if you adjust the Handbrake Cable then you may be ok from then on
Unless it has already been fully adjusted, in which case you may then need to get a new Handbrake Cable
Location of Handbrake Adjustment Rod behind the drivers seat very close to the sill where that Spanner is sticking up
Using 2 Spanners (The Same Size) undo the Locknut and then adjust the Rod which adjusts the Cable
Another View of the Adjusting Rod once you get that locknut undone adjusting the Handbrake Cable is a 'Breeze' (ish)
Old Jan 26, 2018 | 10:03 PM
baxtor's Avatar
I consider myself a reasonably patient man but if the OP still has the handbrake problem some 4 years later while patiently waiting for advice/ fix he has me beat hands down.
Old Jan 28, 2018 | 04:31 PM
Steve M's Avatar
Maybe the handbrake handle adjusting spanner was missing from the toolkit?
BrentGardner
29
Dec 16, 2024 12:13 AM
Stigram
Jun 17, 2022 12:05 PM
DrScientist
Dec 9, 2015 07:36 PM
Lionrod
Aug 30, 2015 12:52 PM
