Power steering pump modifications.
Old Aug 20, 2015 | 09:19 PM
Typhoon's Avatar
Default Power steering pump modifications.
I've read that more than a few people are unhappy with their steering, being over assisted or under assisted.
I stumbled across this page whilst looking for some information on P/S pump outlets and thought it was well worth sharing.
Bear in mind it is written by a four wheel drive enthusiast and obviously they run much more assist due to larger tyres etc, but the principles are the same and it's good information for those who wish to easily play around with pump pressures.
Given how cheap Saginaw pumps are, no big deal if you totally ruin a part either, just go and buy a used pump from a junkyard.
Modifying your Power Steering Pump - GM Truck Central
Old Aug 21, 2015 | 02:00 PM
kenatofc's Avatar
Spent a while last winter rebuilding part of my ps system. Since I was replacing both hoses, to the steering rack, I decided to get a rebuilt pump (ebay). Also redid the radiator overflow as it was easier to remove the pump with it out of the way. Took a while and had to lower the steering rack to get to remove and install the hoses. For less than $200 US, it was well worth it... She drives lovely now. and waiting for the next problem....lol...
good luck
ken
Old Aug 21, 2015 | 05:24 PM
paulyling's Avatar
Interesting.
I am just about to embark on the journey of troubleshooting mine:
https://www.jaguarforums.com/forum/x...eering-148184/
Not sure whats wrong yet.
Old Aug 22, 2015 | 08:27 AM
xjsv12's Avatar
Thank you.
This info is actually for me. I have a big wheels and hard steering. I'll try to do this mod.
Old Aug 23, 2015 | 05:48 PM
ronbros's Avatar
my 78 XJS had an old GM cast iron pump,heavy weight, so i came across a nice light weight alum. pump from a 1995 Dodge Viper(4lbs).
pic of the aluminum front pulley, replace the old cast iron heavy one!
many small weight savings , is why my 1978 XJS V12 roadster weighs 3370lbs.
Attached Thumbnails Power steering pump modifications.-jag-pulley-viper-pump-002.jpg   Power steering pump modifications.-jag-pulley-viper-pump-001.jpg
Old Aug 26, 2015 | 02:26 PM
xjsv12's Avatar
Great, this mod is works. Steering spins freely. I did everything, drilled, pulled up to the spring 2. 25-inch, washers removed from the valve.
Thank to all.
My wife will be happy
Old May 28, 2016 | 06:44 PM
BC XJS's Avatar
Has anyone modified the power steering pump to take power out. My steering seems overpowered. Not as bad as my old Dodges back in the day. But I'd like more road feel.
Old May 29, 2016 | 09:18 AM
Paul_59's Avatar
Banned
Just wondering if you could replace the mechanical power steering pump with an electrically driven pas pump.
Seem to remember a Ford I owned (UK model) had electrohydraulic power steering, had the advantage of variable assistance levels, alternatively would changing the drive pulley to reduce pump speed provide the desired result.
Haven't tried either method, just theorising.
Old May 29, 2016 | 09:22 AM
Daim's Avatar
Loads of sensors needed and a new steering rack...
Old Jun 13, 2016 | 06:35 AM
cityslang's Avatar
Default Power Steering Pump (?)
deleting
dsnyder586
Dec 29, 2024 07:39 PM
Dicque
Sep 19, 2015 12:53 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
