Power window won't go up
Old Jul 2, 2016 | 01:51 PM
Rafal's Avatar
Exclamation Power window won't go up
Hi, I've got a problem with driver power window. It won't go up. I can hear working motor when im trying to get it down but it's silent when i'm going to pull it up. Could you help me?
Old Jul 2, 2016 | 02:54 PM
sov211's Avatar
Very simple: the switch is dirty: you need to remove the switch, take it apart and clean the contacts and put it back together. To prove that the switch us at fault you simply transfer the connector to the passenger side window and vice versa.
Old Jul 2, 2016 | 02:57 PM
Doug's Avatar
Model year and body style are usually helpful but the usual first step is to swap window switches and see if anything changes
Old Jul 2, 2016 | 03:17 PM
Rafal's Avatar
Any tips how to remove this switch?
Old Jul 2, 2016 | 05:58 PM
warrjon's Avatar
If you put your vehicle details in your signature model and year will help the tech guys tailor responses for your car, there a a couple of different setups, are your switches in a plastic faceplate or directly into the console?
Old Jul 3, 2016 | 04:08 AM
Rafal's Avatar
It's 1992 4.0 model (Sorry but my signature didn't show for some reason)
Old Jul 3, 2016 | 05:25 AM
warrjon's Avatar
Being a 92 your switches should be in a bezel, these have tabs on the left and right sides, be careful when you pry them out as they break easy, don't ask, as the plastic becomes brittle over time.
Once out you can remove the switches from the bezel, but before doing this swap the connectors to verify the switch is the problem.
Old Jul 3, 2016 | 09:43 AM
Vee's Avatar
Vee
I think the best tip to remove the bezel starts off with ordering a new bezel. They were NLA for a long time, but are now available again.
I think you'll have to remove the armrest cubbyhole to get to the one screw that keeps the ski slope in place. One the screw is removed, you can angle the ski slope up and stick your hand underneath to ease out the switch assembly, including the ability to disconnect each switch from the harness.
teroks
Oct 2, 2022 04:38 PM
hoober
Jul 26, 2016 09:09 PM
Larry-Cleveland
May 4, 2016 02:30 PM
springer
Apr 22, 2016 11:05 AM
byjosh
Apr 5, 2016 08:05 AM
